跳转到主内容
PlayStation 4 Pro Power Supply Unit Replacement
你所需要的
  1. PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: 步骤 1 中的图像 1,3 PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: 步骤 1 中的图像 2,3 PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: 步骤 1 中的图像 3,3
    • Begin by flipping the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. PlayStation 4 Pro Power Supply Unit Replacement: 步骤 2 中的图像 1,2 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 2 中的图像 2,2
    • Use a screwdriver to remove the single Phillips #0 screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. PlayStation 4 Pro Power Supply Unit Replacement: 步骤 3 中的图像 1,3 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 3 中的图像 2,3 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 3 中的图像 3,3
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. PlayStation 4 Pro Power Supply Unit Replacement: 步骤 4 中的图像 1,3 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 4 中的图像 2,3 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 4 中的图像 3,3
    • Use a T8 Torx Security screwdriver to remove the five screws.
    • Two 31mm screws.
    • Three 10mm screws.
    • Remove the metal plate.
  5. PlayStation 4 Pro Power Supply Unit Replacement: 步骤 5 中的图像 1,3 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 5 中的图像 2,3 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 5 中的图像 3,3
    • Flip the console to its back once again.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel.
    • Remove the bottom cover in the same way as the top cover. Grip on both sides, pull up until a click is heard and slide off.
  6. PlayStation 4 Pro Power Supply Unit Replacement: 步骤 6 中的图像 1,2 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 6 中的图像 2,2
    • Use a T8 Torx security screwdriver to remove the two 10mm silver screws from the metal plate.
  7. PlayStation 4 Pro Power Supply Unit Replacement: 步骤 7 中的图像 1,3 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 7 中的图像 2,3 PlayStation 4 Pro Power Supply Unit Replacement: 步骤 7 中的图像 3,3
    • Flip the console over to continue working on the top side.
    • Place fingers underneath edge of power supply unit on both sides and pull straight up.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
结论
36等其他人完成本指南。
Ashlyn Chow
于04/25/17注册
3,345 声望
撰写一个指南
团队
Cal Poly, Team S21-G5, Livingston Spring 2017 Cal Poly, Team S21-G5, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G5
4 名成员
创作了49篇指南
10条评论
Thank you soooo much for helping me save my ps4 pro guys! At the moment I love you like no one before! ;D
Fayce D D - 回复
Can you go further in your tear-down and show us how to open up the power supply without breaking the PSU plastic case? Thanks. ^_^
Matt - 回复
I bought a PS4 power supply CR 300 and my PS4 has an FR 300 power supply will they interchange
joseph fish - 回复
My PlayStation Pro has a power supply FR 300 and the power supply I bought was a CR 300 power supply will they interchange
joseph fish - 回复
Hola como saber que tipo de fuente vida mi ps4 pro modelo 7215b
Tomás Javier - 回复
添加评论
浏览统计数据:
过去 24 小时: 25
过去 7 天: 168
过去 30 天: 758
总计 91,228
