跳转到主内容
PlayStation 4 Pro Fan Replacement
你所需要的
  1. PlayStation 4 Pro Fan Replacement, Hard Drive Caddy: 步骤 1 中的图像 1,3 PlayStation 4 Pro Fan Replacement, Hard Drive Caddy: 步骤 1 中的图像 2,3 PlayStation 4 Pro Fan Replacement, Hard Drive Caddy: 步骤 1 中的图像 3,3
    • Flip the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. PlayStation 4 Pro Fan Replacement: 步骤 2 中的图像 1,2 PlayStation 4 Pro Fan Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 Screwdriver to remove the single screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. PlayStation 4 Pro Fan Replacement, Power Supply Assembly: 步骤 3 中的图像 1,3 PlayStation 4 Pro Fan Replacement, Power Supply Assembly: 步骤 3 中的图像 2,3 PlayStation 4 Pro Fan Replacement, Power Supply Assembly: 步骤 3 中的图像 3,3
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. PlayStation 4 Pro Fan Replacement: 步骤 4 中的图像 1,3 PlayStation 4 Pro Fan Replacement: 步骤 4 中的图像 2,3 PlayStation 4 Pro Fan Replacement: 步骤 4 中的图像 3,3
    • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
    • Two 31mm screws.
    • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Remove the metal plate by pulling it up.
  5. PlayStation 4 Pro Fan Replacement: 步骤 5 中的图像 1,3 PlayStation 4 Pro Fan Replacement: 步骤 5 中的图像 2,3 PlayStation 4 Pro Fan Replacement: 步骤 5 中的图像 3,3
    • Flip the console over so the bottom is facing up.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
    • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
  6. PlayStation 4 Pro Fan Replacement: 步骤 6 中的图像 1,3 PlayStation 4 Pro Fan Replacement: 步骤 6 中的图像 2,3 PlayStation 4 Pro Fan Replacement: 步骤 6 中的图像 3,3
    • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
    • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
    • 7200-series models have 13 additional 4mm screws around the top and right of the metal plate. These screws are are indicated with a triangle. This may apply to other models.
    • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
  7. PlayStation 4 Pro Fan Replacement: 步骤 7 中的图像 1,2 PlayStation 4 Pro Fan Replacement: 步骤 7 中的图像 2,2
    • Pull the white fan connector straight out of the yellow mount on the motherboard.
  8. PlayStation 4 Pro Fan Replacement: 步骤 8 中的图像 1,2 PlayStation 4 Pro Fan Replacement: 步骤 8 中的图像 2,2
    • Pull out the five small, blue low profile cables connected to the metal plate.
    • Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull the large ribbon cable from its socket.
    • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
  9. PlayStation 4 Pro Fan Replacement: 步骤 9 中的图像 1,1
    • Pull up and remove the metal plate.
  10. PlayStation 4 Pro Fan Replacement: 步骤 10 中的图像 1,3 PlayStation 4 Pro Fan Replacement: 步骤 10 中的图像 2,3 PlayStation 4 Pro Fan Replacement: 步骤 10 中的图像 3,3
    • Flip the console over to continue working on the top side.
    • Pull up on the power supply unit and set it on the console.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
  11. PlayStation 4 Pro Fan Replacement, Motherboard: 步骤 11 中的图像 1,3 PlayStation 4 Pro Fan Replacement, Motherboard: 步骤 11 中的图像 2,3 PlayStation 4 Pro Fan Replacement, Motherboard: 步骤 11 中的图像 3,3
    • If you are working on the 7200-series model, this metal plate will have been already removed as part of the removing the larger motherboard plate. You may skip this step if this is the case.
    • Carefully flip the console over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the eight 4mm screws on the metal plate with the X-like symbol.
    • Use a plastic opening tool to remove the metal plate with the X-like shape.
  12. PlayStation 4 Pro Fan Replacement: 步骤 12 中的图像 1,3 PlayStation 4 Pro Fan Replacement: 步骤 12 中的图像 2,3 PlayStation 4 Pro Fan Replacement: 步骤 12 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the four 13mm screws on the X-shaped metal plate underneath.
    • For 7200-series models this is instead a S-shaped metal plate with 2 screws.
    • Grip the X-shaped retaining bracket and lift straight up.
  13. PlayStation 4 Pro Fan Replacement: 步骤 13 中的图像 1,2 PlayStation 4 Pro Fan Replacement: 步骤 13 中的图像 2,2
    • Grip the edge of the motherboard and slowly lift upwards to remove it from the device.
    • For reassembly, use this guide to reapply thermal paste between the motherboard and the metal plate underneath.
  14. PlayStation 4 Pro Fan Replacement, Heat Pipe: 步骤 14 中的图像 1,2 PlayStation 4 Pro Fan Replacement, Heat Pipe: 步骤 14 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 6 mm silver screws from the metal plate.
  15. PlayStation 4 Pro Fan Replacement: 步骤 15 中的图像 1,2 PlayStation 4 Pro Fan Replacement: 步骤 15 中的图像 2,2
    • Lift the metal plate that is connected to the heat pipe straight up to remove it.
  16. PlayStation 4 Pro Fan Replacement, Fan: 步骤 16 中的图像 1,3 PlayStation 4 Pro Fan Replacement, Fan: 步骤 16 中的图像 2,3 PlayStation 4 Pro Fan Replacement, Fan: 步骤 16 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the two 6mm screws on the fan.
    • On 7200-series models these screws will be on the right of the fan.
    • Grab the fan and lift up to remove it.
结论
98等其他人完成本指南。
Thomas
于04/26/17注册
3,521 声望
创作了5篇指南
团队
Cal Poly, Team S21-G5, Livingston Spring 2017 Cal Poly, Team S21-G5, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G5
4 名成员
创作了49篇指南
12条评论
Danke für die Anleitung. hat alles super geklappt. Bloß beim letzten Schritt ist die Schraube vom Lüfter nicht oben links sondern unten rechts. Mfg
Camorrista31 - 回复
Thanks for the guide. Very comprehensive.
Paul Swinglehurst - 回复
I’m clueless with electronics but my PS4 was on its death throes with overheating. I read this guide and watched the video (coffee break included) and got to work. The only trouble I had was that my husband (he’s a good guy normally) decided to help and used too big pliers and broke the connector between the power supply and PS4. Ok, so 5 days wait for replacement. I replaced the fan, thermal paste, and pads and put it back together (shaking like a leaf in a hurricane). It’s quiet and works thanks to ifixit.com. Thank you so much!
K. Birks - 回复
This was super helpful! For the power supply, I was trying to pull at the socket the cable was plugged into (same color plastic). I think it would have worked better just wiggling the cable.
Also, T8 worked fine, but putting it back together, I noticed T9 was better fit, so if you have a T9, use that instead. After cleaning and repasting, it’s so much quieter. Thanks!
Phil - 回复
Great guide. I did have a little difficulty getting the power supply connector removed, but I tried to be patient and eventually got it. Thanks!
JTG - 回复
添加评论
浏览统计数据:
过去 24 小时: 72
过去 7 天: 422
过去 30 天: 2,390
总计 134,491
