简介
本指南展示移除 PlayStation 4 Pro 供电模组的必要步骤。此次操作需要一些拆解,但这是第一批可以从 PS4 Pro 上移除的部件之一。
你所需要的
使用一个 T8 梅花安全螺丝刀从设备上移除5个螺丝。
两个 31mm 螺丝。
三个 10mm 螺丝。
移除金属板。
I couldn’t open the middle 10mm screw with T8 Torx Security screwdriver :(
Rifat Nabi - 回复
How do I get the middle plastic black screw out? It's not doing anything but stripping it.
it’s like rubber or something on that middle screw.
On newer models the black screw in the middle is just plastic and does not have to be removed. Skip it or you’ll just drive yourself crazy and end up producing a small pile of plastic-dust and that’s it.
将主机倒放。
使用一个 T8 梅花安全螺丝刀移除背板上的3个黑色 7mm 螺丝。
使用和移除顶部盖板一样的方法移除底部改版。抓住盖板的两边,用力拉直到听到咔哒的声音。然后滑至脱离。
If you have a console that has not been fixed before - these screws will be hidden under warranty stickers - so make sure you understand that completing this step will basically void the warranty.
将主机翻过来,在正面继续。
拉起供电模组,放在主机上。
抓住供电模组后的连接器直接拔出来。
what kind of wire is that ive been looking everywhere for a replacement
There are 3 different power supplies for the pro model.......... take it apart and read the numbers off it to make sure you get the correct one. 300ER, 300CR, 300FR
Alan Sears - 回复
This is the only screw I can't get out on top of the power supply so I can replace my pasta what size is it
This is the screw I had trouble with I don't know why and it's the only screw holding the power supply in on top in the middle when you take the foil off
要重新组装设备,请按相反的顺序操作。
要重新组装设备,请按相反的顺序操作。
36等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
10条评论
I bought a PS4 power supply CR 300 and my PS4 has an FR 300 power supply will they interchange
My PlayStation Pro has a power supply FR 300 and the power supply I bought was a CR 300 power supply will they interchange
Hola como saber que tipo de fuente vida mi ps4 pro modelo 7215b
Solucionaste el problema?
for anyone attempting this please note that the motherboard connector for the power supply is very fragile and might break off will trying to disconnect. Try pinching the connector on the motherboard and gently pulling on the cables to try and keep that from happening
Good morning do you have a number to call for I can call about a ps4 Pro
Because I need my PS4 to get fixed I think one of the cords inside of it is broken and it do not want to turn on and stuff like that so ya what is the number I can contact you on
