跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
PlayStation 4 Pro 热管更换
你所需要的
  1. PlayStation 4 Pro 热管更换, 硬盘架: 步骤 1 中的图像 1,3 PlayStation 4 Pro 热管更换, 硬盘架: 步骤 1 中的图像 2,3 PlayStation 4 Pro 热管更换, 硬盘架: 步骤 1 中的图像 3,3
    • 把主机倒过来。
    • 用手指拉断覆盖在硬盘上的塑料片。
    DON’T FORGET TO HAVE THERMAL PASTE HANDY! It should be added to the “Tools Required” Section. You will NEED it!
    Jaquell Chandler - 回复
    What if thermal paste is not applied again when remounting ? Will the playstation start and work anyway or not ?
    Vincent Bee - 回复
    It will start and run normally until you put it under load. Then it will heat up and thermal throttle or it can overheat and destroy itself.
    Jeremy Ivey -
    I posted this down in another step too, but: if you have a very early North American PS4 Pro, with the exact optical drive shown here - the key way to tell is the very long data cable that’s folded a couple of times, see pictures in later steps - then the replacement drive iFixit offers WILL NOT WORK IN YOUR MACHINE. It has to be a very early model, apparently, but the model number isn’t enough to tell you.
    Even if you swap the too-short cables in their replacement with the longer cables on your drive, it still will not work. At all. It’ll just sit there like the drive isn’t even getting power.
    So if you do have this drive, what you probably need to do is get a replacement KES-496A Optical Pickup Assembly and replace that within your existing drive. That’s what I had to do after two different replacement drives sent by iFixit failed to work in my system. It worked immediately and I’m back online.
    The optical pickup replacement is awfully fiddly, and adds a solid 20 minutes to the repair easily. But it does work.
    Dara Korra'ti - 回复
    I had originally been told by several people that to properly repair the optical drive within the PS4 Pro (so that the PS4 actually works), you have to replace the Optical Pickup Assembly like you mentioned because the drive is paired with the motherboard. I was surprised to find that iFixit is pushing this repair tutorial when it has a low probability of success for many PS4 Pro models.
    Instead, iFixit should be documenting replacement of the KES-496A Optical Pickup Assembly... when that repair has a near 100% chance of success, even though it's a fair bit more fiddly to complete and requires two different teardowns (one for the PS4 Pro and one for the optical drive... needed to install the replacement optical pickup assembly).
    commorancy -
    Follow-on note. I could be mixing up the original PS4's pairing with the PS4 Pro (which might or might not have device + motherboard pairing). Because I can't find a definitive source confirming if the drive is paired on the PS4 Pro, using a drive replacement might or might not work.
    There are a number of commenters below who followed these instructions and found that the replacement drive didn't work after completing the repair. I think I'd still go with replacing the KES-496A Optical Pickup Assembly. That repair is more fiddly, but the optical assembly replacement part is a whole lot cheaper, costing less than $10 in some stores, than buying a full replacement drive at $70.
    commorancy -
  2. PlayStation 4 Pro 热管更换: 步骤 2 中的图像 1,2 PlayStation 4 Pro 热管更换: 步骤 2 中的图像 2,2
    • 使用一个 #0 十字螺丝刀移除一个固定硬盘架的螺丝。
    • 拉出硬盘架。
    This is a Phillips #1 bit.
    Trevor Frey - 回复
  3. PlayStation 4 Pro 热管更换, 电源组件: 步骤 3 中的图像 1,3 PlayStation 4 Pro 热管更换, 电源组件: 步骤 3 中的图像 2,3 PlayStation 4 Pro 热管更换, 电源组件: 步骤 3 中的图像 3,3
    • 主机正面朝上。
    • 抓住主机前部的两个角。
    • 用力向上拉直到听见一声响亮的咔哒。
    • 这可能需要大力出奇迹,所以不要害怕对你的主机施加一点点暴力。
    • 在两个角都分开了以后,将盖子向后滑至脱离。
    %#*@. I thought I was gonna break the thing. You really do have to give it some elbow grease.
    Addison Francisco - 回复
    there were also some screws that needed to come out before popping it off. Might have been a different version im working on. there were three screws attached to the console that I had to remove before popping off the top.
    Ricky Arias - 回复
    The 7215B has one TR8 security Torx behind the center “void” sticker.
    cylentstorm - 回复
    This cover is really on there. It sounds like your breaking plastic when you pop it open. I ended up using a metal tablespoon in the corners where you should pull up to pop the cover up the first bit, worked well.
    azade91 - 回复
  4. PlayStation 4 Pro 热管更换: 步骤 4 中的图像 1,3 PlayStation 4 Pro 热管更换: 步骤 4 中的图像 2,3 PlayStation 4 Pro 热管更换: 步骤 4 中的图像 3,3
    • 使用一个 T8 梅花安全螺丝刀从设备上移除5个螺丝。
    • 两个 31mm 螺丝。
    • 三个 10mm 螺丝。
    • 拉起金属板来移除它。
    I copy the comment written by Jason at the end of this guide, because it’s better to have it here:
    This guide is for the initial release CUH-7000 models. Of note is the changes to the CUH-7100 series that do make this guide an issue. Steps 4 and 5 have a different items to note. You can damage it following this guide if you don’t adjust. There no longer 3 security screws for the case, but just one. This single screw is still covered by a warranty sticker, but the second one is a blank sticker and no screw behind it. There is also no 10mm screw in the center power supply in Step 4, it’s a support post. You still remove the 4 other screws, but you must then flip the console over and remove a T8 screw to the right on the HDD cage and another closer to the right side. You can then flip the console over again to remove the battery and plug it. Just remove all the metal plate screws to be sure, but make sure you hold the board when you flip it again or you will bend the battery prongs like I found out the hard way.
    kautame - 回复
    Oh! That explains why I stripped the middle screw. What’s a support post?
    Philippe Morin -
    Had to use TR8 instead of 10mm here.
    After I popped the top off, I got 4 out of 5 screws out. The 5 th screw for some reason, was a little bit bigger, therefore, I could not take out that screw so I could clean the heatsink and fan.
    Dixie Dawg - 回复
    Me too it’s not like another screw it’s have black and I can’t remove if you know pls tell me how i do bro ???
    Montri Meka -
    I stripped the %#*@ screw in the middle. (orange highlighting) It’s a black head and the T8 Torx Security head doesn’t work! I have a CUH-7115B. I think it’s a regular T8 or some kind of Hex head. ? I don’t know what to do now!! :(
    Philippe Morin - 回复
    As mentioned above, this guide is for the old models. 7215B: There 4 TR8 screws (2 long, 2 short) holding the plate. The middle is a support post.
    cylentstorm - 回复
  5. PlayStation 4 Pro 热管更换: 步骤 5 中的图像 1,3 PlayStation 4 Pro 热管更换: 步骤 5 中的图像 2,3 PlayStation 4 Pro 热管更换: 步骤 5 中的图像 3,3
    • 将主机倒放。
    • 使用一个 T8 梅花安全螺丝刀移除背板上的3个黑色 7mm 螺丝。
    • 使用和移除顶部盖板一样的方法移除底部改版。抓住盖板的两边,用力拉直到听到咔哒的声音。然后滑至脱离。
    Adding to this, the screws are not visible unless you remove the warranty stickers!
    George Diaz - 回复
    Also, the plastic on the back of the cover is prone to cracking. Be careful and undo snaps across the whole back of the panel gently!
    Nick Podrebarac - 回复
    Vielen vielen Dank. Endlich ist der jumbojet gelandet #fan
    Christian Radke - 回复
    7215B has 1 TR8 screw beneath a sticker between the optical and USB ports, and two clips (1 next to the HDD slot and 1 beneath a sticker near the power port.)
    cylentstorm - 回复
  6. PlayStation 4 Pro 热管更换: 步骤 6 中的图像 1,3 PlayStation 4 Pro 热管更换: 步骤 6 中的图像 2,3 PlayStation 4 Pro 热管更换: 步骤 6 中的图像 3,3
    • 使用一个 T8 安全梅花螺丝从金属板上移除11个 10mm 银色螺丝。
    • 使用一个 #0 十字螺丝从金属板上移除11个 4mm 黑色螺丝。
    • 拔下通过金属板连接到主板小部分的三根电缆。
    • 电缆接口可能会很锋利。
    Noted during my replacement that the PS4 Pro appears to have additional #0 Phillips Head screws in Step 6 required to remove the metal plate from the motherboard and that the metal “X” plate in Step 11 appears to be included now in this overall metal cover for the motherboard, no longer separate, which accounts for the additional screws.
    David Carlsen - 回复
    Original pro here. Had 12 torx
    Skyler Cook - 回复
    cuh0-7216b have more philips #1 screws on metal plate on right, +13 screws :)
    Papolo0 - 回复
    (PS4 Pro) Bei mir ebenfalls 11 T8 Torx, von denen 3 Sicherheitstorx waren.
    Rebecca Dorsch - 回复
    My PS4 Pro 7115 has additional sets of #0 Phillips screws on the plate. 10x in the primary processor space (blank plate area of the graphic here), 2x over the fan, and 1x on the outside edge to clamp down on the primary processor area. Model CUH-7115B
    r0flm4k3r - 回复
    What are the 3 different antennas identifications or functionality ?
    Robert Aldred - 回复
  7. PlayStation 4 Pro 热管更换: 步骤 7 中的图像 1,2 PlayStation 4 Pro 热管更换: 步骤 7 中的图像 2,2
    • 将白色连接器从主板上的黄色支架中直接拉出。
  8. PlayStation 4 Pro 热管更换: 步骤 8 中的图像 1,2 PlayStation 4 Pro 热管更换: 步骤 8 中的图像 2,2
    • 拔出连接到金属板上的五根小的蓝色薄型电缆。
    • 抬起大型带状电缆的ZIF连接器上的固定盖板。
    • 将大型带状电缆从插槽中拔出。
    • 不要在没有抬起固定盖板的情况下拔出最大的那根蓝色电缆,否则会造成连接器的损坏。
    What the cable in the up left corner is for? I broke it and i’d like to know at what is it connected?
    Thanks
    Enrico Pensalfine - 回复
    The blue ribbon cables aren’t connected to the metal plate. The plate can be safely removed beforehand. The only thing one should do prior to its removal is de route the antenna cables for the WNIC.
    Robert - 回复
  9. PlayStation 4 Pro 热管更换: 步骤 9 中的图像 1,1
    • 拉起并移除金属板。
  10. PlayStation 4 Pro 热管更换: 步骤 10 中的图像 1,3 PlayStation 4 Pro 热管更换: 步骤 10 中的图像 2,3 PlayStation 4 Pro 热管更换: 步骤 10 中的图像 3,3
    • 将主机翻过来,在正面继续。
    • 拉起供电模组,放在主机上。
    • 小心别拉得太远,该组件仍然在一点上有连接。
    • 抓住供电模组后的连接器直接拔出来。
    Why do I have to remove the PSU here? I do not see the necessity judging by the following steps.
    Alexander Bla - 回复
    This comes in handy when removing the entire motherboard which is necessary when cleaning the heat sink.
    George Diaz -
    Bonjour, Que se soit le connecteur du bloc comme celui sur la partie ps4 , il est difficile à retirer ce câblage… peut-on tirer sans risque réellement ?
    Brezu Sama - 回复
    IMPORTANT: The connector on the motherboard is very sensitive. I’d recommend using pliers to put pressure down on the connector while slowly jerking the cable out of the socket to avoid serious damage to the connector and/or motherboard that could render the PSU connection useless and require advanced soldering / rewiring.
    Daniel Larusso - 回复
    This!
    Connector was quite tight in PSU side and I ended pulling connector from motherboard resulting me getting PS5 for Christmas.
    tero -
    Also der stecke lässt sich nicht entfernen
    Slime - 回复
    Der Stecker am Netzteil (letzter Schritt) erscheint mir ungewöhnlich fest, und lässt sich ohne weiteres nicht entfernen. Besteht die Möglichkeit, dass dieser neuerdings verklebt ist oder dergleichen? :-/
    Rebecca Dorsch - 回复
    Das würde mich auch interessieren. Ich habe den Stecker weder vom Mainboartd noch von der PSU abbekommen. Leider habe ich den Stecker dann abgerissen - aber er hat sich auf keiner Seite abziehen lassen.
    Tobias August -
    Bei dieser Stecker-Buchse Verbindung handelt es sich um einen Molex-Stecker, der verriegelt ist. An der Seite befindet sie ein kleiner Hebel, den man nach innen drücken muss, damit sich der Stecker löst.
    Volker Diederichs - 回复
    Danke für die Info!
    Fabian Neidhardt -
  11. PlayStation 4 Pro 热管更换, 主板: 步骤 11 中的图像 1,3 PlayStation 4 Pro 热管更换, 主板: 步骤 11 中的图像 2,3 PlayStation 4 Pro 热管更换, 主板: 步骤 11 中的图像 3,3
    • 小心的把主机翻过来使底部朝上。
    • 使用 #1 十字螺丝刀移除有“X”印记的金属板上的八颗 4mm 螺丝。
    • 使用一个塑料撬棒移除有“X”印记的金属板。
    My PS4 Pro 7115, this and more is integrated with the main plate, as noted above, plus there are 10 in this area (not 8), along with 2 over the fan and 1 to the edge of this area. Model CUH-7115B
    r0flm4k3r - 回复
  12. PlayStation 4 Pro 热管更换: 步骤 12 中的图像 1,3 PlayStation 4 Pro 热管更换: 步骤 12 中的图像 2,3 PlayStation 4 Pro 热管更换: 步骤 12 中的图像 3,3
    • 使用一个 #1 十字螺丝刀移除下面的“X”型金属板上的四颗 13mm 螺丝。
    • 抓住“X”型金属板固定支架并抬起。
    Mine had an S shape with two screws.
    Christopher - 回复
    Depending on the series it will have either a S or X shape bracket
    Jeremy Ivey -
    My PS4 Pro 7115 has an S-shaped bracket with 2 screws. Model CUH-7115B
    r0flm4k3r - 回复
    I have heatsink issue 7016 (x-shaped). However I am only able to find S shaped heatsink plate (71xx model) in my country. Does anyone know how the heatpipes travel within the heatsink? I basically need to drill 2 more holes and thread it to put the x clamp. Also the hole and thread size would be helpful.
    rn nr - 回复
  13. PlayStation 4 Pro 热管更换: 步骤 13 中的图像 1,2 PlayStation 4 Pro 热管更换: 步骤 13 中的图像 2,2
    • 抓住主板的一边并缓慢的抬起来将其从设备上移开。
    • 如需重新组装,使用该指南来在主板和下面的金属板之间重新涂抹导热膏。
    Does anybody know the name of the white detail from the first screenshot step #13? (Plastic with square metal inside). I broke it by accident during dissembling and want to find replacement for it, but can’t find it anywhere.
    serjgord - 回复
    I can read F2-4 >POM< on the plastic piece but i guess thisis a radiator/thermal dissipator support. HTH
    Vincent Bee -
    Won't you also need a paired optical drive to replace the motherboard? My ps4 got broken some weeks ago and I've found out that I need to replace the motherboard for it to work again, but I keep seeing that you also need a paired optical drive. Is this true? My ps4 pro is a CUH-7216B if that helps
    Jekabs Freimanis - 回复
    A warning should be before this step that this step detaches from the primary heat sync. The required tools should list the replacement thermal paste at the beginning, not after the step is already to have been completed.
    r0flm4k3r - 回复
    tut euch selbst den gefallen und tauscht auch alle Wärmeleitpads. (ca 14 stück)
    Jim Bean - 回复
  14. PlayStation 4 Pro 热管更换, 热管: 步骤 14 中的图像 1,2 PlayStation 4 Pro 热管更换, 热管: 步骤 14 中的图像 2,2
    • 使用一个 #0 十字螺丝刀来移除金属板上的两颗 6mm 银色螺丝。
    Where to get the pink stuff from?
    Dark Flo - 回复
    #1 Philips screwdriver
    Peter - 回复
  15. PlayStation 4 Pro 热管更换: 步骤 15 中的图像 1,2 PlayStation 4 Pro 热管更换: 步骤 15 中的图像 2,2
    • 抬起连接着热管的金属板并直接提起来移除。
    The second screw is at the right bottom side !!
    mobilas77 - 回复
结论
要重新组装设备,请按相反的顺序操作。
42等其他人完成本指南。
由衷感谢以下译者:
en zh
83%
Patrick Zhang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Thomas
于04/26/17注册
3,877 声望
创作了5篇指南
团队
Cal Poly, Team S21-G5, Livingston Spring 2017 Cal Poly, Team S21-G5, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G5
4 名成员
创作了49篇指南
3条评论
Ist es schlimm, wenn man die 2 schrauben von schritt 14 vergessen hat zum verschrauben?
AxoN z - 回复
Can anyone explain what are those 5 blocks near heatsink as mine are broken when I open it 2 blocks have converted into dust plz help
rajatagg41 - 回复
This guide doesn't tell how to change the Heat Pipe on the later models. In my 72xx version, the Heat Pipe can be seperated from the chassis plating with 4 screws (ph#1)
TdG - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 109
过去 30 天: 476
总计 65,202
