简介
目前索尼已经推出3款不同型号的 PS4 系列游戏机。这个型号是目前最新的版本,相比之前两款它已经改变了很多。我们把它打开,看看有什么不同之处。
- 您在参考本指南中请风险自负。TronicsFix 对使用本指南中所发生的任何损害事件概不负责,也不承担任何连带责任。
使用拨子或其他类似的东西,剥掉保修贴纸后会露出两个黑色的 T9 梅花螺丝钉。
移除这两颗 T9 梅花螺丝钉。
这是我们发现的第一个重大改动......只有两个螺丝钉来固定。 在这以前的型号有四个。
使用相同的钳子夹住 WiFi 天线电缆并小心拉起。
光驱线缆有一个黑色的“领子”,需要在每一侧抬起。 这将断开与光驱的连接。
另外两根线缆可以直接从相应的插槽中拔出。
我们现在可以看到老款机型和这款新机型之间的巨大差异之一,主板一侧没有RAM!
RAM数量仍然相当,但RAM芯片的总数已经减少了一半。
在其他发现中,HDMI端口终于被重新设计了! 这是一个好消息,因为旧式很容易失败。
114等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
73条评论
You didn't show what the supply connector is supposed to look like, when disconnected. Now I ripped it off of my mother board, attempting to assess milk damage. Thanks for helping me make sure my PS4 will stay broken.
I'm so sorry it ripped off. I'm assuming you are talking about the power supply connector? If so step #10 shows the method we use to remove this connector. We use mini pliers and grasp one end at a time and pull up gently but firmly each time...this will eventually get the connector off without damage in most cases. That being said we have had to fix a connector every once in a while on these because some of them are fragile.
I ripped off my power supply from the motherboard too, assuming that from these photos that was where I was supposed to pull. Playstation is very broken now.
Same here. I really don’t know what I’m supposed to do now.
i dropped my ps4 and it made grinding noises when it reading discs and also it wouldnt eject disc, i fixed the eject problem by disassembling the blu ray drive but it still grinds when reading and only reads when i rebuild database. are you guys gonna start selling replacements anytime soon or will the blu ray from the cuh-11xx models work?
