跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
PlayStation 3 Slim Top Shield Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. PlayStation 3 Slim Top Shield Assembly Replacement, Top Shield Assembly: 步骤 1 中的图像 1,1
    • Disconnect the DC-In and Blu-ray power cables from the motherboard.
    • Pull the cables straight upward to lift the connectors up and out of their sockets on the motherboard.
  2. PlayStation 3 Slim Top Shield Assembly Replacement: 步骤 2 中的图像 1,1
    • Pull the fan cables straight up to lift the fan connector up and out of its socket on the motherboard.
  3. PlayStation 3 Slim Top Shield Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the following nine screws holding the motherboard assembly together:
    • Four 14.8 mm shouldered Phillips
    • Five 9.5 mm Phillips
  4. PlayStation 3 Slim Top Shield Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the two heat sink clamps from the bottom of the motherboard assembly.
  5. PlayStation 3 Slim Top Shield Assembly Replacement: 步骤 5 中的图像 1,1
    • If necessary, gently pry the motherboard off the top shield near the heat sink and its shroud.
  6. PlayStation 3 Slim Top Shield Assembly Replacement: 步骤 6 中的图像 1,2 PlayStation 3 Slim Top Shield Assembly Replacement: 步骤 6 中的图像 2,2
    • Gently press the board away from the top shield assembly near the fan connector and the corner of the board near the wireless sockets.
  7. PlayStation 3 Slim Top Shield Assembly Replacement: 步骤 7 中的图像 1,1
    • Lift the top shield assembly off the motherboard from its front edge.
    • Be careful not to damage the sockets as you rotate the top shield assembly away from the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,748
