当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Disconnect the DC-In and Blu-ray power cables from the motherboard.
Pull the cables straight upward to lift the connectors up and out of their sockets on the motherboard.
Pull the fan cables straight up to lift the fan connector up and out of its socket on the motherboard.
Remove the following nine screws holding the motherboard assembly together:
Four 14.8 mm shouldered Phillips
Five 9.5 mm Phillips
Remove the two heat sink clamps from the bottom of the motherboard assembly.
If necessary, gently pry the motherboard off the top shield near the heat sink and its shroud.
Gently press the board away from the top shield assembly near the fan connector and the corner of the board near the wireless sockets.
Lift the top shield assembly off the motherboard from its front edge.
Be careful not to damage the sockets as you rotate the top shield assembly away from the motherboard.
取消:我没有完成这个指南。
与4其他贡献者
586,588 声望
创作了619篇指南
徽章: 47
+ 44更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 1,756
