简介
Video Source-Shawn Shakir on YouTube
Check them out here.
On the Playstation 3, the NEC/TOKIN capacitors are prone to failure, causing a Yellow Light if Death error. This is a guide on replacing those capacitors.
The Yellow Light of Death is not an error with one specific fix; rather, it is a more general failure. This guide addresses ONE of the POTENTIAL problems causing a PS3 Yellow Light of Death, however, these capacitors are prone to failure anyway, so they should be replaced (if you are experienced enough) to help the longevity of the console.
你所需要的
视频概述
Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
Remove the following seven screws:
Six 52 mm Phillips screws
One 30 mm Phillips screw
Lift the top cover from its rear edge and rotate it toward the front of the PS3.
Remove the top cover.
There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
Pull the control board ribbon cable straight up and out of its socket on the motherboard.
While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover.
De-route the fan cables from the plastic finger molded into the heat sink.
Disconnect the fan from the motherboard.
Flip up the retaining flap on the Blu-ray ribbon cable socket.
Remove the Blu-ray ribbon cable.
2等其他人完成本指南。
2条评论
Replacing capacitors doesn't fully fix it forever. Only an RSX replacement does.
https://www.youtube.com/watch?v=I0UMG3iV...
I have updated the title and description of the guide to reflect that this is a potential solution.
Andrew S -
