跳转到主内容
PlayStation 3 Potential YLOD Fix
你所需要的
视频概述
  1. PlayStation 3 Potential YLOD Fix, Smart Plate: 步骤 1 中的图像 1,2 PlayStation 3 Potential YLOD Fix, Smart Plate: 步骤 1 中的图像 2,2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Potential YLOD Fix: 步骤 2 中的图像 1,1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Potential YLOD Fix: 步骤 3 中的图像 1,3 PlayStation 3 Potential YLOD Fix: 步骤 3 中的图像 2,3 PlayStation 3 Potential YLOD Fix: 步骤 3 中的图像 3,3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Potential YLOD Fix: 步骤 4 中的图像 1,1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Potential YLOD Fix, Top Cover: 步骤 5 中的图像 1,1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Potential YLOD Fix: 步骤 6 中的图像 1,1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Potential YLOD Fix, Blu-ray Disc Drive: 步骤 7 中的图像 1,1
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. PlayStation 3 Potential YLOD Fix: 步骤 8 中的图像 1,1
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. PlayStation 3 Potential YLOD Fix: 步骤 9 中的图像 1,3 PlayStation 3 Potential YLOD Fix: 步骤 9 中的图像 2,3 PlayStation 3 Potential YLOD Fix: 步骤 9 中的图像 3,3
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
  10. PlayStation 3 Potential YLOD Fix, Motherboard Assembly: 步骤 10 中的图像 1,1
    • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  11. PlayStation 3 Potential YLOD Fix: 步骤 11 中的图像 1,2 PlayStation 3 Potential YLOD Fix: 步骤 11 中的图像 2,2
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
    • Remove the control board and its attached cable from the PS3.
  12. PlayStation 3 Potential YLOD Fix: 步骤 12 中的图像 1,1
    • Remove the following eight screws securing the motherboard assembly to the lower case:
    • Seven 12 mm Phillips screws (ph2)
  13. PlayStation 3 Potential YLOD Fix: 步骤 13 中的图像 1,1
    • Remove the control board bracket.
  14. PlayStation 3 Potential YLOD Fix: 步骤 14 中的图像 1,2 PlayStation 3 Potential YLOD Fix: 步骤 14 中的图像 2,2
    • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
    • Remove the hard drive bay cover.
  15. PlayStation 3 Potential YLOD Fix: 步骤 15 中的图像 1,1
    • Lift the motherboard assembly out of the lower case.
  16. PlayStation 3 Potential YLOD Fix, AC Inlet: 步骤 16 中的图像 1,1
    • Remove the 7.7 mm Phillips screw securing the ground strap to the chassis.
  17. PlayStation 3 Potential YLOD Fix: 步骤 17 中的图像 1,2 PlayStation 3 Potential YLOD Fix: 步骤 17 中的图像 2,2
    • Pull the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
    • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
  18. PlayStation 3 Potential YLOD Fix: 步骤 18 中的图像 1,1
    • Pull the AC inlet out from the bottom of the rear cover, minding any of its cables that may get caught.
  19. PlayStation 3 Potential YLOD Fix, Rear Cover: 步骤 19 中的图像 1,2 PlayStation 3 Potential YLOD Fix, Rear Cover: 步骤 19 中的图像 2,2
    • While lightly pulling the rear cover away from the logic board assembly, use the flat end of a spudger to release the clips along the top and bottom edges of the rear cover.
  20. PlayStation 3 Potential YLOD Fix: 步骤 20 中的图像 1,1
    • Remove the rear cover from the logic board assembly.
  21. PlayStation 3 Potential YLOD Fix, Heat Sink: 步骤 21 中的图像 1,2 PlayStation 3 Potential YLOD Fix, Heat Sink: 步骤 21 中的图像 2,2
    • De-route the fan cables from the plastic finger molded into the heat sink.
    • Disconnect the fan from the motherboard.
  22. PlayStation 3 Potential YLOD Fix: 步骤 22 中的图像 1,1
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  23. PlayStation 3 Potential YLOD Fix: 步骤 23 中的图像 1,2 PlayStation 3 Potential YLOD Fix: 步骤 23 中的图像 2,2
    • Lift the memory card reader out of the PS3 enough to access its ribbon cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Pull the ribbon cable out of its socket and remove the memory card reader.
  24. PlayStation 3 Potential YLOD Fix: 步骤 24 中的图像 1,1
    • Disconnect the DC-In cables from the front of the heat sink.
    • Pull the connector toward the front of the PS3.
  25. PlayStation 3 Potential YLOD Fix: 步骤 25 中的图像 1,1
    • Remove the five 9 mm Phillips screws securing the power supply to the chassis.
  26. PlayStation 3 Potential YLOD Fix: 步骤 26 中的图像 1,1
    • Lift the power supply by its front edge to clear the two posts attached to the motherboard.
    • Remove the power supply.
  27. PlayStation 3 Potential YLOD Fix: 步骤 27 中的图像 1,1
    • Remove the four 16.5 mm shouldered Phillips screws securing the heat sink to the motherboard.
    • Remove the two brackets held under the screws you just removed.
  28. PlayStation 3 Potential YLOD Fix: 步骤 28 中的图像 1,1
    • Lift the motherboard assembly off the heat sink.
    • The heat sink may still be held in place by the thermal paste. If this is the case, gently pry the heat sink away from the motherboard housing. Make sure to not bend the copper piping on the heat sink.
    • Be sure to apply a new layer of thermal paste when reattaching the heat sink.
    • Never applied thermal paste before? Our thermal paste guide makes it easy.
    • If you're following the YLOD repair guide, stay tuned for where to apply the replacement thermal paste.
  29. PlayStation 3 Potential YLOD Fix, Motherboard: 步骤 29 中的图像 1,2 PlayStation 3 Potential YLOD Fix, Motherboard: 步骤 29 中的图像 2,2
    • Flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Remove the Blu-ray ribbon cable.
  30. PlayStation 3 Potential YLOD Fix: 步骤 30 中的图像 1,2 PlayStation 3 Potential YLOD Fix: 步骤 30 中的图像 2,2
    • Flip up the flap on the memory card reader ribbon cable socket and remove the ribbon cable.
  31. PlayStation 3 Potential YLOD Fix: 步骤 31 中的图像 1,2 PlayStation 3 Potential YLOD Fix: 步骤 31 中的图像 2,2
    • Flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket.
    • Pull the Wi-Fi/Bluetooth ribbon cable out of its socket.
  32. PlayStation 3 Potential YLOD Fix: 步骤 32 中的图像 1,1
    • Disconnect the DC-In cable from the motherboard and set it aside.
    • Pull the connector straight up and out of its socket on the motherboard.
  33. PlayStation 3 Potential YLOD Fix: 步骤 33 中的图像 1,1
    • Disconnect the PRAM battery from the motherboard.
    • The PRAM socket is delicate and has the potential to break off the motherboard. If possible, hold down the socket as you disconnect the PRAM battery cable.
  34. PlayStation 3 Potential YLOD Fix: 步骤 34 中的图像 1,3 PlayStation 3 Potential YLOD Fix: 步骤 34 中的图像 2,3 PlayStation 3 Potential YLOD Fix: 步骤 34 中的图像 3,3
    • Rotate the PRAM battery slightly counter-clockwise and remove it from the motherboard assembly.
  35. PlayStation 3 Potential YLOD Fix: 步骤 35 中的图像 1,1
    • Remove the blue 8 mm Phillips screw securing the hard drive cage to the chassis.
  36. PlayStation 3 Potential YLOD Fix: 步骤 36 中的图像 1,3 PlayStation 3 Potential YLOD Fix: 步骤 36 中的图像 2,3 PlayStation 3 Potential YLOD Fix: 步骤 36 中的图像 3,3
    • Push the hard drive cage toward the front of the motherboard assembly.
    • Remove the hard drive from the motherboard assembly.
  37. PlayStation 3 Potential YLOD Fix: 步骤 37 中的图像 1,1
    • Remove the two 3.7 mm #0 Phillips screws securing the chassis to the hard drive socket.
  38. PlayStation 3 Potential YLOD Fix: 步骤 38 中的图像 1,1
    • Remove the two 8.3 mm #0 Phillips screws securing the two halves of the motherboard together.
  39. PlayStation 3 Potential YLOD Fix: 步骤 39 中的图像 1,1
    • Carefully feed the Wi-Fi/Bluetooth ribbon cable through the hole in the top motherboard cover.
    • Remove the top motherboard cover.
  40. PlayStation 3 Potential YLOD Fix: 步骤 40 中的图像 1,1
    • Remove the motherboard from the bottom motherboard cover.
  41. PlayStation 3 Potential YLOD Fix: 步骤 41 中的图像 1,2 PlayStation 3 Potential YLOD Fix: 步骤 41 中的图像 2,2
    • Remove the Wi-Fi/Bluetooth ribbon cable from the motherboard.
    • Motherboard remains.
    • Locate the NEC/TOKIN capacitors on your motherboard.
    • Choose one capacitor to start with.
    • Pry the plastic top off of the capacitor using a metal spudger.
    • Remove the rest of the capacitor remnants.
    • Clean up the area with Rubbing Alcohol and a toothbrush/cotton bud (or similar).
    • Tin the pads with a small amount of solder.
  42. PlayStation 3 Potential YLOD Fix: 步骤 48 中的图像 1,1
    • Place the new capacitors at a small angle, making sure to place the capacitors the right way around.
    • The outer rail is the positive side.
    • Heat the soldering iron up and tin the tip.
    • Solder one side of the capacitor, then solder the other side.
    • Solder the other 3 capacitors onto the PS3 motherboard.
    • Repeat this process for the other 7 NEC/TOKIN capacitors on the PS3 motherboard.
结论
2等其他人完成本指南。
Andrew S
于07/30/21注册
14,993 声望
创作了8篇指南
2条评论
Replacing capacitors doesn't fully fix it forever. Only an RSX replacement does.
https://www.youtube.com/watch?v=I0UMG3iV...
Andre Brait - 回复
I have updated the title and description of the guide to reflect that this is a potential solution.
Andrew S -
添加评论
浏览统计数据:
过去 24 小时: 22
过去 7 天: 145
过去 30 天: 599
总计 13,953
