当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Flip the headset face down.
Squeeze both sides of the battery cover.
While squeezing, pull the cover up slowly to remove it.
After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
Use the plastic opening tool to separate the speaker casing from the headset face.
Add extra heat to the sides to melt the adhesive between the plastic connectors.
Flip the device over.
Use a soldering iron to remove the solder that holds the wires to the motherboard.
For help soldering, click here.
The microphone piece should be completely detached from the motherboard.
Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
Using a plastic opening tool, prop open the edges.
Gently pull the black speaker casing up to remove it.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
