当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
The screw only needs to be turned a couple of times.
Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
Pry the board connection with the 2 black wires from the terminal.
BE CAREFUL: Do not pull hard by the wires or you may dislodge them from the connection instead of removing the connection from the board.
Pull out the wires through the opening in the top of the grip and replace the solenoid.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
