跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Picstart Plus Development Programmer,应参考我们的维修指南
  1. Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: 步骤 1 中的图像 1,3 Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: 步骤 1 中的图像 2,3 Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: 步骤 1 中的图像 3,3
    • Remove 4 Phillips screws located on the back side of the holding plate.
    • After the screws are removed, remove the case of the development programmer.
    • Carefully take out the circuit board with component side facing up. Put the case aside.
  2. Picstart Plus Development Programmer Teardown: 步骤 2 中的图像 1,2 Picstart Plus Development Programmer Teardown: 步骤 2 中的图像 2,2
    • Disconnect the microcontroller module from the main board using a spudger or a similar tool.
    • Set the microcontroller module aside.
  3. Picstart Plus Development Programmer Teardown: 步骤 3 中的图像 1,2 Picstart Plus Development Programmer Teardown: 步骤 3 中的图像 2,2
    • Flip over the mainboard so that the component side is facing down and remove the small Pan head screws that holds the cover of the IC holder
    • Remove the cover of the IC holder.
  4. Picstart Plus Development Programmer Teardown: 步骤 4 中的图像 1,2 Picstart Plus Development Programmer Teardown: 步骤 4 中的图像 2,2
    • Remove the IC holder lever along with the small metal plate that covers the lever.
    • Set the lever and the lever cover aside.
  5. Picstart Plus Development Programmer Teardown: 步骤 5 中的图像 1,1
    • Congratulations! You have completely dismantled the PICSTART Plus Development Programmer!
    • All the extracted components are shown in the picture.
Brad
于11/17/13注册
656 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 107
总计 3,007
