简介
This guide will be helpful in the case that your device will not charge or has been dislodged. In this guide you will be using a #1 and #1.5 screwdriver, to remove screws and components. Once you have access to the motherboard, locate and use soldering techniques to remove USB connector.
你所需要的
Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
Identify the motherboard and three Phillips (Length-1/8", Head-1/8") screws and remove them using a #1 screwdriver.
3条评论
Any way to buy the entire motherboard? Any suggestion where can I buy it?
Where can I purchase the usb
Where can I purchase the usb. There are so meany I don't know how to tell the correct one. Thank
