跳转到主内容
Photive Hydra Bluetooth Connector Replacement
你所需要的
  1. Photive Hydra Bluetooth Connector Replacement, Face Plate and Back Plate: 步骤 1 中的图像 1,1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Bluetooth Connector Replacement: 步骤 2 中的图像 1,2 Photive Hydra Bluetooth Connector Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Bluetooth Connector Replacement: 步骤 3 中的图像 1,1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Bluetooth Connector Replacement: 步骤 4 中的图像 1,1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Bluetooth Connector Replacement: 步骤 5 中的图像 1,2 Photive Hydra Bluetooth Connector Replacement: 步骤 5 中的图像 2,2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Bluetooth Connector Replacement, Battery (Prerequisite): 步骤 6 中的图像 1,2 Photive Hydra Bluetooth Connector Replacement, Battery (Prerequisite): 步骤 6 中的图像 2,2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra Bluetooth Connector Replacement: 步骤 7 中的图像 1,1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra Bluetooth Connector Replacement, Bluetooth Connector: 步骤 8 中的图像 1,2 Photive Hydra Bluetooth Connector Replacement, Bluetooth Connector: 步骤 8 中的图像 2,2
    • Identify the motherboard and the three Philips (Length-1/8,Head-1/8) screws and remove them using a #1 Phillips screwdriver.
  9. Photive Hydra Bluetooth Connector Replacement: 步骤 9 中的图像 1,2 Photive Hydra Bluetooth Connector Replacement: 步骤 9 中的图像 2,2
    • Pull the motherboard up and out to dislodge it.
    • Do not fully remove your motherboard to prevent any unwanted severing of connections.
  10. Photive Hydra Bluetooth Connector Replacement: 步骤 10 中的图像 1,1
    • Identify the Bluetooth connector device.
  11. Photive Hydra Bluetooth Connector Replacement: 步骤 11 中的图像 1,1
    • The two solder points shown are to be removed by use of a soldering gun. Remove and replace the component with a functioning connector device. Refer to the link below for soldering techniques. 如何焊接和拆焊
结论
Matthew Knight
于02/09/16注册
246 声望
创作了2篇指南
团队
USF Tampa, Team 11-3, Cheng Spring 2016 USF Tampa, Team 11-3, Cheng Spring 2016 的会员
USFT-CHENG-S16S11G3
5 名成员
创作了6篇指南
一条评论
So any leads on where to get the module?
Charles - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 328
