跳转到主内容
Philips Sonicare HX6710 Replacing the Battery
你所需要的
  1. Philips Sonicare HX6710 Replacing the Battery, Open housing: 步骤 1 中的图像 1,3 Philips Sonicare HX6710 Replacing the Battery, Open housing: 步骤 1 中的图像 2,3 Philips Sonicare HX6710 Replacing the Battery, Open housing: 步骤 1 中的图像 3,3
  2. Philips Sonicare HX6710 Replacing the Battery, Remove lower cap: 步骤 2 中的图像 1,2 Philips Sonicare HX6710 Replacing the Battery, Remove lower cap: 步骤 2 中的图像 2,2
    • Remove lower cap (2 plastic tabs). O-ring is already removed in this picture.
    • Here are the solder connections of the battery: + (red) and - (yellow).
  3. Philips Sonicare HX6710 Replacing the Battery, Replace the battery: 步骤 3 中的图像 1,2 Philips Sonicare HX6710 Replacing the Battery, Replace the battery: 步骤 3 中的图像 2,2
    • Unwrap the battery and replace it (see Soldering Skills).
    • To avoid a short circuit (the battery will normally still have a remaining charge), start at the positive pole of the battery and unsolder completely from the board.
    • Continue with the negative pole.
    • At the end, loosen the soldering pads from remaining solder, so that the contacts of the new battery can be inserted into the board.
    • Solder teh positive and negative pole.
    • Requires a 3.7V battery, which is approximately 14mm x 49mm (similar to AA).
  4. Philips Sonicare HX6710 Replacing the Battery, controls: 步骤 4 中的图像 1,2 Philips Sonicare HX6710 Replacing the Battery, controls: 步骤 4 中的图像 2,2
    • Before assembly, check the upper seal and the lower O-ring and replace those if necessary.
结论
4等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Michael S.
于12/10/17注册
636 声望
创作了4篇指南
一条评论
I saw in another guide that it is advisable, before working on the Li-Ion battery, to break the join between the two pads of JP1 which disconnects the battery.
This is very important due to the volatile nature of Lithium-Ion batteries.
It also takes away some risk of shorting out the battery when we remove it.
So with the solder, before working, break the join between the two pads of JP1.
And at the end, after replaced the battery, re-join the two solder pads of JP1.
Albyee - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 108
总计 6,145
