跳转到主内容
Philips Sonicare DiamondClean Motor Replacement
你所需要的
  1. Philips Sonicare DiamondClean Motor Replacement, Motor: 步骤 1 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement, Motor: 步骤 1 中的图像 2,2
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Motor Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Motor Replacement: 步骤 3 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement: 步骤 3 中的图像 2,2
    • Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
    • Note that there are clips inside the case but they are hard to access and unneeded to separate the components.
  4. Philips Sonicare DiamondClean Motor Replacement: 步骤 4 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement: 步骤 4 中的图像 2,2
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Motor Replacement: 步骤 5 中的图像 1,1
    • Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
  6. Philips Sonicare DiamondClean Motor Replacement: 步骤 6 中的图像 1,1
    • Slide and separate the two components of the internals from each other.
  7. Philips Sonicare DiamondClean Motor Replacement: 步骤 7 中的图像 1,1
    • Gently remove the spring and rubber component.
  8. Philips Sonicare DiamondClean Motor Replacement: 步骤 8 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement: 步骤 8 中的图像 2,2
    • Remove the two 4mm Phillips #00 screws on both sides of the upper component.
  9. Philips Sonicare DiamondClean Motor Replacement: 步骤 9 中的图像 1,2 Philips Sonicare DiamondClean Motor Replacement: 步骤 9 中的图像 2,2
    • Gently bend and position the brackets to remove the motor.
  10. Philips Sonicare DiamondClean Motor Replacement: 步骤 10 中的图像 1,1
    • Remove the motor and replace.
结论
另外一个人完成了本指南。
2条评论
Do you have a part number for the motor?
Suraj Daryapurkar - 回复
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
Marsya Kaustentein - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 47
过去 30 天: 143
总计 7,410
