跳转到主内容
Philips Sonicare DiamondClean Metal Brush Connector Replacement
你所需要的
  1. Philips Sonicare DiamondClean Metal Brush Connector Replacement, Case Replacement: 步骤 1 中的图像 1,2 Philips Sonicare DiamondClean Metal Brush Connector Replacement, Case Replacement: 步骤 1 中的图像 2,2
    • Pull the head from toothbrush.
  2. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 2 中的图像 1,2 Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 2 中的图像 2,2
    • Use a nylon spudger to pry the chrome cap at the bottom off.
    Cover the toothbrush with a thin towel or some cardboard, then take a pair of pliers or channel locks and squeeze the corners to slightly deform the case. That will give you some room to get under the cap.
    Maybe Dave - 回复
  3. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 3 中的图像 1,1
    • Use a nylon spudger to release the black tabs on either side of internals.
    This is the most difficult part but it can be done once one understands how the tabs that need to be unlocked are designed and located. The difficulty is in seeing the tabs -- they are black - and especially the way they lock in, on the body.
    There are two tabs - one each side - built on the internal frame holding the battery and electronic circuitry. They are pushing towards the outside, and each locks inside a recessed hole on the internal side of the toothbrush body.
    They are most effectively unlocked by going deeper with the spudger and unlocking them by going behind them and hooking them from below, going in from the top opening. IMPORTANT NOTE The tabs need to be PUSHED from the outside TOWARDS the inside of the unit, i.e. towards the chassis that holds the battery and electronics. Trying to pushing the external toothbrush shaft from above will only damage the mechanism. The only way - on this latest Sonicare model- is to unlock these two black tabs.
    MASINARI - 回复
    This was invaluable but I still couldnt quite picture it. So I want to add: you can see the tabs MASINARI is speaking about on the picture seen at step 6. They are the little wings at the bottom end of the 'side panels' . If you shine a light into the opened toothbrush, you should be able to see them. The holes are recessed into the shell of the toothbrush. It worked for me to push the tabs from the side downwards. Once they are lose, the body of the toothbrush will slide out of the shell with only little pressure.
    some_guy - 回复
    I wrapped the open end of the base with cardboard and then with channel locks squeezed on the two short sides while pushing down on the metal brush head on a hard surface and it popped right out
    PhilR - 回复
  4. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 4 中的图像 1,2 Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 4 中的图像 2,2
    • Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
  5. Philips Sonicare DiamondClean Metal Brush Connector Replacement, Metal Brush Connector Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips screwdriver to remove the screw at the base of the metal head.
  6. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use fine tip tweezers to push the white plastic tabs in to release the head from the innards.
  7. Philips Sonicare DiamondClean Metal Brush Connector Replacement: 步骤 7 中的图像 1,1
    • Gently pull the metal head from the innards.
    Wie benennt man " den Rest des Gerätes" gemäß obiger Beschreibung? Das Gussteil ist bei mir gebrochen. Ich würde dieses gern nachbestellen. FG Reinhold
    Reinhold - 回复
    Google liefert für "hx93 Antrieb" Einiges, kommt oft aus China. Bei eBay heißt es "Vibrationsteil":
    https://www.ebay.de/itm/174961352222
    VauWeh -
    this is all great instruction on how to get this apart and to get that head out BUT there is no link to buy the replacement head in the USA. A gentleman posted a link, but it’s for eBay only sold in the UK.
    Bummer
    PhilR - 回复
    Follow up: once I had this part, I noticed that one side of the brush head (where the white plastic tabs are clipped into the metal case) had popped out on its own. I put the head back in place put everything back together and now it functions properly.
    PhilR - 回复
结论
9等其他人完成本指南。
团队
IUPUI, Team S22-G1, Bayer Fall 2017 IUPUI, Team S22-G1, Bayer Fall 2017 的会员
IUPUI-BAYER-F17S22G1
4 名成员
创作了9篇指南
8条评论
Great guide - but where is a good source for replacement parts?
Christian Zischek - 回复
Ordered replacement part, came within 3 days at ebay. Didn’t have to replace the soft rubber inlet parts, only the connector.
Piece of cake, exchange of battery seems more labourous, but the brush still works for two weeks, so we postpone this job.
Emilio - 回复
Gut beschrieben, aber wo bekomme ich eine neue Antriebsachse?
Beste Grüße - pechi606
Walter P - 回复
Z.B. direkt aus China : ebay
VauWeh -
Great post, thank-you. One question: My toothbrush has a wire loop around the head. The loop is soldered to the circuit board. Do you know what that wire is for? Cheers!
tim belina - 回复
It should be the antenna for the function that detects when to change the head
Norbert Takács -
vielfach ist nur die Schraube locker - mit Loktite sichern und es hält (zumindest wieder für eine Weile)
Roger - 回复
Amazing! I fixed it. The screw holding the head on had just come loose. I tightened it and put it back together and we're off to the races.
Pap - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 60
过去 30 天: 280
总计 20,848
