跳转到主内容
Philips Sonicare DiamondClean Circuit Board Replacement
你所需要的
  1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,2 Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 2,2
    • Pull the brush head from the toothbrush.
  2. Philips Sonicare DiamondClean Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Circuit Board Replacement: 步骤 3 中的图像 1,3 Philips Sonicare DiamondClean Circuit Board Replacement: 步骤 3 中的图像 2,3 Philips Sonicare DiamondClean Circuit Board Replacement: 步骤 3 中的图像 3,3
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Carefully free the top end of the circuit board from the plastic clips holding it in place.
  6. Philips Sonicare DiamondClean Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
    • Remove the circuit board.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 48
总计 3,434
