跳转到主内容
Philips Sonicare 2 Series Motor Replacement
你所需要的
  1. Philips Sonicare 2 Series Motor Replacement, Philips Sonicare 2 Series Disassembly: 步骤 1 中的图像 1,1
    • Pull upwards to remove the brush head from the top of the device.
  2. Philips Sonicare 2 Series Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
  3. Philips Sonicare 2 Series Motor Replacement: 步骤 3 中的图像 1,2 Philips Sonicare 2 Series Motor Replacement: 步骤 3 中的图像 2,2
    • Remove the internal electronic mechanism from the housing by prying the red clips shown in the figure. This removes the charging port.
    • Be very careful not to damage the charging port during this step. Otherwise you will have to solder this part back to the device as shown in the second figure.
  4. Philips Sonicare 2 Series Motor Replacement: 步骤 4 中的图像 1,1
    • Next you will be able to remove the internal electronic mechanism as shown in the figure.
  5. Philips Sonicare 2 Series Motor Replacement: 步骤 5 中的图像 1,1
    • Remove the white battery cover as shown in the figure.
  6. Philips Sonicare 2 Series Motor Replacement: 步骤 6 中的图像 1,1
    • Remove the white circuit board cover as shown. This cover will require you to pry off the piece from the groves .
  7. Philips Sonicare 2 Series Motor Replacement, Motor: 步骤 7 中的图像 1,1
    • Disassemble the device. Remove the plastic piece over the brush attachment as shown. Object can be removed by hand as shown. No tool is required.
  8. Philips Sonicare 2 Series Motor Replacement: 步骤 8 中的图像 1,1
    • Desolder the motor from the circuit board at the two locations shown.
  9. Philips Sonicare 2 Series Motor Replacement: 步骤 9 中的图像 1,1
    • Remove the bad motor.
终点
Jonathan Jarvis
于04/01/16注册
491 声望
创作了4篇指南
团队
IUPUI, Team S6-G2, Baechle Fall 2017 IUPUI, Team S6-G2, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S6G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 30
总计 2,535
