跳转到主内容
加入维修社区 - 创建账户
Philips Somneo LED Assembly Replacement
你所需要的
  1. Philips Somneo LED Assembly Replacement, Antenna: 步骤 1 中的图像 1,1
    • Remove the four silicone feet on the bottom plate.
    • Remove the following Phillips screws from the bottom plate:
    • Two 9 mm screws
    • Two 13 mm screws
  2. Philips Somneo LED Assembly Replacement: 步骤 2 中的图像 1,2 Philips Somneo LED Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the bottom plate from the device.
  3. Philips Somneo LED Assembly Replacement: 步骤 3 中的图像 1,2 Philips Somneo LED Assembly Replacement: 步骤 3 中的图像 2,2
    • Disconnect the antenna connector by pulling it directly out of its port.
    • Remove the antenna.
  4. Philips Somneo LED Assembly Replacement, Motherboard: 步骤 4 中的图像 1,2 Philips Somneo LED Assembly Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove the four 9 mm Phillips screws securing the motherboard.
  5. Philips Somneo LED Assembly Replacement: 步骤 5 中的图像 1,2 Philips Somneo LED Assembly Replacement: 步骤 5 中的图像 2,2
    • Gently pull the motherboard down until the cables are visible.
    • Take care not to strain the connected cables.
  6. Philips Somneo LED Assembly Replacement: 步骤 6 中的图像 1,3 Philips Somneo LED Assembly Replacement: 步骤 6 中的图像 2,3 Philips Somneo LED Assembly Replacement: 步骤 6 中的图像 3,3
    • Remove each cord by gently disconnecting each connector with your hand.
  7. Philips Somneo LED Assembly Replacement: 步骤 7 中的图像 1,3 Philips Somneo LED Assembly Replacement: 步骤 7 中的图像 2,3 Philips Somneo LED Assembly Replacement: 步骤 7 中的图像 3,3
    • Continue gently removing each cord with you hand.
  8. Philips Somneo LED Assembly Replacement: 步骤 8 中的图像 1,2 Philips Somneo LED Assembly Replacement: 步骤 8 中的图像 2,2
    • Finish gently removing the final cord attached to the motherboard to successfully remove the motherboard.
  9. Philips Somneo LED Assembly Replacement, LED Assembly: 步骤 9 中的图像 1,3 Philips Somneo LED Assembly Replacement, LED Assembly: 步骤 9 中的图像 2,3 Philips Somneo LED Assembly Replacement, LED Assembly: 步骤 9 中的图像 3,3
    • Use an opening pick to pry underneath the plastic covering the edges of the screen.
    • Place an opening tool in the space made between the screen and this plastic piece and pry up, working around the length of this circular piece to significantly loosen it.
  10. Philips Somneo LED Assembly Replacement: 步骤 10 中的图像 1,2 Philips Somneo LED Assembly Replacement: 步骤 10 中的图像 2,2
    • The panel should be loosened significantly enough to be pulled off the main body, revealing the edges of the screen.
  11. Philips Somneo LED Assembly Replacement: 步骤 11 中的图像 1,2 Philips Somneo LED Assembly Replacement: 步骤 11 中的图像 2,2
    • Remove the two 13 mm Phillips #0 screws on the bottom edges of the screen.
    • Remove the 9 mm Phillips #0 screws on the upper edge of the screen.
  12. Philips Somneo LED Assembly Replacement: 步骤 12 中的图像 1,3 Philips Somneo LED Assembly Replacement: 步骤 12 中的图像 2,3 Philips Somneo LED Assembly Replacement: 步骤 12 中的图像 3,3
    • Remove the display assembly.
  13. Philips Somneo LED Assembly Replacement: 步骤 13 中的图像 1,3 Philips Somneo LED Assembly Replacement: 步骤 13 中的图像 2,3 Philips Somneo LED Assembly Replacement: 步骤 13 中的图像 3,3
    • On the back of the screen, remove the four 9 mm Phillips #00 screws, disconnecting the LED assembly.
  14. Philips Somneo LED Assembly Replacement: 步骤 14 中的图像 1,3 Philips Somneo LED Assembly Replacement: 步骤 14 中的图像 2,3 Philips Somneo LED Assembly Replacement: 步骤 14 中的图像 3,3
    • Two cables connected to the LED were once connected to the motherboard, but are still attached to the body. They are threaded through black ovals connected to the body by a hard black adhesive.
    • Using a metal spudger, scrape underneath this adhesive and pry up, freeing the cable from the body. Repeat this for the other cable to free the LED.
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
另外一个人完成了本指南。
Ryan Borges
于03/21/25注册
213 声望
撰写一个指南
团队
UMass Dartmouth, Team 6-1, Botvin Spring 2025 UMass Dartmouth, Team 6-1, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S6G1
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 145
