简介
The suppression capacitor in the Senseo Quadrante unfortunately often breaks down. The machine then no longer starts or the pump fails. The exchange is quite simple. You need a 0.47uF capacitor, class X2, at least 275 V, 22 mm pitch, which is easily available at any electronics store.
The repair goes quite similar to other devices
你所需要的
Remove all attachments such as cup rack, pod holder and water tank.
The side panel must first be detached at the bottom edge. Turn the machine so that the bottom is facing towards you.
There are two indentations on the base plate with catches inside each one. Press in the catches with a screwdriver and detach the side panel at the bottom edge.
Chances are the plate will get stuck. It is recommended that you use a plastic pry tool to avoid scratching.
Work through the steps in reverse order to reassemble your device.
2等其他人完成本指南。
由衷感谢以下译者:
100%
shingle正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
Let op de + en - aansluiting van de condensator!
Dit type condensator heeft geen polariteit. Heb je de verkeerde condensator geïnstalleerd?
VauWeh -
