跳转到主内容
Philips Norelco 5801XL Battery Replacement
你所需要的
  1. Philips Norelco 5801XL Battery Replacement, Battery: 步骤 1 中的图像 1,2 Philips Norelco 5801XL Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: 步骤 2 中的图像 1,2 Philips Norelco 5801XL Battery Replacement: 步骤 2 中的图像 2,2
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: 步骤 3 中的图像 1,3 Philips Norelco 5801XL Battery Replacement: 步骤 3 中的图像 2,3 Philips Norelco 5801XL Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: 步骤 5 中的图像 1,1
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: 步骤 7 中的图像 1,3 Philips Norelco 5801XL Battery Replacement: 步骤 7 中的图像 2,3 Philips Norelco 5801XL Battery Replacement: 步骤 7 中的图像 3,3
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
结论
3等其他人完成本指南。
Ben Gibbs
于02/16/16注册
361 声望
创作了3篇指南
团队
IUPUI, Team 3-2, Harley Spring 2016 IUPUI, Team 3-2, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S3G2
4 名成员
创作了3篇指南
2条评论
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - 回复
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 32
总计 4,118
