跳转到主内容
Pentax Optio WG-2 Menu Buttons Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. 注意:步骤 1-6 源自标记为进行中的 指南
    Pentax Optio WG-2 Menu Buttons Replacement, Back Case: 步骤 1 中的图像 1,2 Pentax Optio WG-2 Menu Buttons Replacement, Back Case: 步骤 1 中的图像 2,2
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 Menu Buttons Replacement: 步骤 2 中的图像 1,1
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 Menu Buttons Replacement: 步骤 3 中的图像 1,1
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 Menu Buttons Replacement: 步骤 4 中的图像 1,3 Pentax Optio WG-2 Menu Buttons Replacement: 步骤 4 中的图像 2,3 Pentax Optio WG-2 Menu Buttons Replacement: 步骤 4 中的图像 3,3
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 Menu Buttons Replacement: 步骤 5 中的图像 1,1
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 Menu Buttons Replacement: 步骤 6 中的图像 1,1
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 Menu Buttons Replacement, Menu Buttons: 步骤 7 中的图像 1,2 Pentax Optio WG-2 Menu Buttons Replacement, Menu Buttons: 步骤 7 中的图像 2,2
    • Remove the eight JS#000 screws using a screwdriver and lift panel up.
    • This screw does not need to be removed.
  8. Pentax Optio WG-2 Menu Buttons Replacement: 步骤 8 中的图像 1,1
    • Once panel is removed the button 'sheet' can be removed.
结论
团队
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 UMass Dartmouth, Team 6-7, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S6G7
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 187
