简介
Use this guide to remove and replace a damaged battery cover on the Pentax Optio WG-2.
你所需要的
步骤 1 Back Case
注意:步骤 1-6 源自标记为进行中的 指南。
Remove all four 1 mm JIS #00 screws from the back of the camera.
Lift the cover as you normally would if replacing battery.
Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
即将完成!
结论
