跳转到主内容
Patching a Bicycle Tire Inner Tube
你所需要的
  1. Patching a Bicycle Tire Inner Tube, Inner Tube: 步骤 1 中的图像 1,1
    • Press the valve core while applying pressure to the tire to deflate the tire.
  2. Patching a Bicycle Tire Inner Tube: 步骤 2 中的图像 1,2 Patching a Bicycle Tire Inner Tube: 步骤 2 中的图像 2,2
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  3. Patching a Bicycle Tire Inner Tube: 步骤 3 中的图像 1,1
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  4. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: 步骤 4 中的图像 1,2 Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: 步骤 4 中的图像 2,2
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  5. Patching a Bicycle Tire Inner Tube: 步骤 5 中的图像 1,1
    • Mark the hole with a marker, and completely deflate the tire.
  6. Patching a Bicycle Tire Inner Tube: 步骤 6 中的图像 1,1
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  7. Patching a Bicycle Tire Inner Tube: 步骤 7 中的图像 1,1
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  8. Patching a Bicycle Tire Inner Tube: 步骤 8 中的图像 1,1
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  9. Patching a Bicycle Tire Inner Tube: 步骤 9 中的图像 1,1
    • Apply the patch to the area.
  10. Patching a Bicycle Tire Inner Tube: 步骤 10 中的图像 1,1
    • Apply pressure to the patch until the rubber cement is dry.
结论
To reassemble your bike, follow these directions from step 6
2等其他人完成本指南。
Brett Hartt
于04/12/10注册
131,199 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,629篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 2,063
