跳转到主内容
Parrot Skycontroller 2 Power Port Replacement
你所需要的
  1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: 步骤 1 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: 步骤 1 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: 步骤 1 中的图像 3,3
    • Flip the controller upside down.
  2. Parrot Skycontroller 2 Power Port  Replacement: 步骤 2 中的图像 1,1
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Power Port  Replacement: 步骤 3 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 3 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool into the top of the battery cover and pry upwards to lift the cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Power Port  Replacement: 步骤 4 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 4 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 4 中的图像 3,3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling apart.
  5. Parrot Skycontroller 2 Power Port  Replacement: 步骤 5 中的图像 1,2 Parrot Skycontroller 2 Power Port  Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from it's brackets by pulling up gently on the ends of the battery.
    • Some force may be required to separate the battery from it's brackets.
  6. Parrot Skycontroller 2 Power Port  Replacement: 步骤 6 中的图像 1,1
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
  7. Parrot Skycontroller 2 Power Port  Replacement: 步骤 7 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 7 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 7 中的图像 3,3
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 Power Port  Replacement: 步骤 8 中的图像 1,1
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 Power Port  Replacement: 步骤 9 中的图像 1,1
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 Power Port  Replacement: 步骤 10 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 10 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 10 中的图像 3,3
    • Remove the face plate by pulling up and out.
  11. Parrot Skycontroller 2 Power Port  Replacement: 步骤 11 中的图像 1,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 11 中的图像 2,3 Parrot Skycontroller 2 Power Port  Replacement: 步骤 11 中的图像 3,3
    • Make sure the controller is flat, then proceed to desolder the power port.
    • Desolder the four connection points surrounding the charging port.
    • Remove the power port from the controller.
    • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
    • Excessive heat can damage the power port, so do not apply the soldering iron to the component for too long.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 629
