跳转到主内容
Panasonic PV-GS9 Logic Board Replacement
你所需要的
  1. Panasonic PV-GS9 Logic Board Replacement, Microphone Replacement: 步骤 1 中的图像 1,3 Panasonic PV-GS9 Logic Board Replacement, Microphone Replacement: 步骤 1 中的图像 2,3 Panasonic PV-GS9 Logic Board Replacement, Microphone Replacement: 步骤 1 中的图像 3,3
    • Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
  2. Panasonic PV-GS9 Logic Board Replacement: 步骤 2 中的图像 1,2 Panasonic PV-GS9 Logic Board Replacement: 步骤 2 中的图像 2,2
    • Open the tape compartment.
    • Then flip the camcorder and locate two 4.5mm screws that are horizontal from each other and about 2 inches apart using a #00 Phillips screwdriver.
  3. Panasonic PV-GS9 Logic Board Replacement: 步骤 3 中的图像 1,3 Panasonic PV-GS9 Logic Board Replacement: 步骤 3 中的图像 2,3 Panasonic PV-GS9 Logic Board Replacement: 步骤 3 中的图像 3,3
    • Use the blue plastic opening tool to remove the gray trim piece by prying it from top of the camcorder.
    • Be gentle when removing the trim piece. The plastic parts are fragile and can break easily.
  4. Panasonic PV-GS9 Logic Board Replacement: 步骤 4 中的图像 1,1
    • Rotate the camcorder so that the eye piece is facing you.
    • Remove the four black 4.5mm screws, sitting behind the battery.
    • Remove the 5th screw to the right of the battery dock.
    • Remove the battery by gently pulling away from the camcorder.
    • Be careful and place screws together so you don't lose any.
  5. Panasonic PV-GS9 Logic Board Replacement: 步骤 5 中的图像 1,2 Panasonic PV-GS9 Logic Board Replacement: 步骤 5 中的图像 2,2
    • Rotate the camcorder so that the tape compartment is facing you.
    • Remove the single 4.5mm black screw above the hook for the hand strap.
    • Undoing the strap on one end may help.
    • Rotate the camcorder so that the lens is facing you.
    • Remove the single 4.5mm black screw from the front panel.
  6. Panasonic PV-GS9 Logic Board Replacement: 步骤 6 中的图像 1,2 Panasonic PV-GS9 Logic Board Replacement: 步骤 6 中的图像 2,2
    • Rotate the camcorder so that the bottom is facing towards you.
    • Remove the single remaining 4.5mm black screw from the bottom.
    • Remove the four silver 4.5mm screws from the body.
  7. Panasonic PV-GS9 Logic Board Replacement: 步骤 7 中的图像 1,1
    • Open the LCD screen on the side of the camcorder.
    • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
  8. Panasonic PV-GS9 Logic Board Replacement: 步骤 8 中的图像 1,2 Panasonic PV-GS9 Logic Board Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the front cover from the body of the camcorder.
    • This should come apart with relative ease, however a plastic opening tool may help remove the panel.
    • There is a ribbon cable attached to the front panel and the camcorder body, DO NOT pull that off when you remove this panel.
  9. Panasonic PV-GS9 Logic Board Replacement: 步骤 9 中的图像 1,2 Panasonic PV-GS9 Logic Board Replacement: 步骤 9 中的图像 2,2
    • Using your fingers, carefully pull the ribbon cable away from the logic board.
  10. Panasonic PV-GS9 Logic Board Replacement, LCD Panel Removal: 步骤 10 中的图像 1,2 Panasonic PV-GS9 Logic Board Replacement, LCD Panel Removal: 步骤 10 中的图像 2,2
    • Remove the indicated 4.5mm screws from the LCD side of the camera.
  11. Panasonic PV-GS9 Logic Board Replacement: 步骤 11 中的图像 1,3 Panasonic PV-GS9 Logic Board Replacement: 步骤 11 中的图像 2,3 Panasonic PV-GS9 Logic Board Replacement: 步骤 11 中的图像 3,3
    • Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
    • Using two tools may be useful, if difficult.
    • Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
    • Remove the panel from the camcorder.
  12. Panasonic PV-GS9 Logic Board Replacement: 步骤 12 中的图像 1,3 Panasonic PV-GS9 Logic Board Replacement: 步骤 12 中的图像 2,3 Panasonic PV-GS9 Logic Board Replacement: 步骤 12 中的图像 3,3
    • Before removing the LCD panel from the camcorder, disconnect the ribbon cables joining the LCD panel to the logic board.
    • There may be multiple ribbon cables attached to the same point on the logic board.
  13. Panasonic PV-GS9 Logic Board Replacement, Logic Board: 步骤 13 中的图像 1,3 Panasonic PV-GS9 Logic Board Replacement, Logic Board: 步骤 13 中的图像 2,3 Panasonic PV-GS9 Logic Board Replacement, Logic Board: 步骤 13 中的图像 3,3
    • Using the spudger, remove the few remaining ribbon cables from the logic board.
  14. Panasonic PV-GS9 Logic Board Replacement: 步骤 14 中的图像 1,3 Panasonic PV-GS9 Logic Board Replacement: 步骤 14 中的图像 2,3 Panasonic PV-GS9 Logic Board Replacement: 步骤 14 中的图像 3,3
    • To remove the logic board from the body, use the #00 phillips head screwdriver and remove the 4mm silver screw from right side of the board.
    • Next, rotate the camcorder so the front is facing you and remove the 4mm silver screw from the front panel.
    • Carefully lift the logic board away from the camcorder.
结论
另外一个人完成了本指南。
Tommy
于04/18/10注册
118 声望
创作了2篇指南
团队
Cal Poly, Team 7-9, Maness Spring 2010 Cal Poly, Team 7-9, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G9
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 2,932
