跳转到主内容
加入维修社区 - 创建账户
Panasonic DVD-RV31 Player Disk Drive Replacement
你所需要的
  1. Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Tray Cover: 步骤 1 中的图像 1,1
    • Eject the disk tray from the DVD player before removing power supply.
  2. Panasonic DVD-RV31 Player Disk Drive Replacement: 步骤 2 中的图像 1,1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. Panasonic DVD-RV31 Player Disk Drive Replacement, Outer Case: 步骤 3 中的图像 1,2 Panasonic DVD-RV31 Player Disk Drive Replacement, Outer Case: 步骤 3 中的图像 2,2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. Panasonic DVD-RV31 Player Disk Drive Replacement: 步骤 4 中的图像 1,1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. Panasonic DVD-RV31 Player Disk Drive Replacement, Front Panel: 步骤 5 中的图像 1,2 Panasonic DVD-RV31 Player Disk Drive Replacement, Front Panel: 步骤 5 中的图像 2,2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  6. Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Drive: 步骤 6 中的图像 1,3 Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Drive: 步骤 6 中的图像 2,3 Panasonic DVD-RV31 Player Disk Drive Replacement, Disk Drive: 步骤 6 中的图像 3,3
    • Locate the four screws securing the disk drive assembly. There are two on each side.
    • Use a narrow screwdriver to remove all four screws.
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
  7. Panasonic DVD-RV31 Player Disk Drive Replacement: 步骤 7 中的图像 1,1
    • Lift assembly by the front to pull metal bracket from the power board.
    • Pull up back end and lift drive out.
  8. Panasonic DVD-RV31 Player Disk Drive Replacement: 步骤 8 中的图像 1,1
    • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
    • Lift bracket off and reserve for re-assembly.
结论
2等其他人完成本指南。
William
于04/26/11注册
283 声望
创作了2篇指南
团队
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 的会员
CPSU-GARNER-S11S18G20
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 50
总计 6,066
