当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Position the phone so the screen faces down.
Remove the stylus found on the back of the phone.
Hold the button in the middle of the phone's back to remove the battery cover.
Slide the cover down to remove it, and set the cover aside.
Lift the edge of the battery, separating contact points, and pull out as pictured.
Remove the round, rubber cover to expose a screw that will be removed in the next step.
Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
Pull the antenna outward to remove the antenna from the body of the phone.
Pry the back cover off using an iFixit opening tool.
Several small clips on the inside attach to the back cover.
Disconnect the ribbon cable before removing the motherboard.
Unclip the gray tab.
Pull out the orange ribbon cable.
Pull off the motherboard.
Pull out the earphone by grabbing the black rubber piece identified in the picture.
取消:我没有完成这个指南。
与9其他贡献者
于10/28/09注册
122 声望
创作了7篇指南
徽章: 10
+ 7更多徽章
CPSU-MANESS-F09S19G3
4 名成员
创作了18篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 15
总计 2,987
