当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Rotate the device so that the display faces forward.
Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
Pry along the crevice to loosen the back panel.
Repeat this process for the right side.
Carefully pry the back panel to open the device.
Be careful not to break the wire that connects the battery pack to the motherboard.
When reassembling, snap the back panel back into place and then insert the top cover.
Use a soldering iron to disconnect the battery wires from the motherboard.
For soldering instructions, you can view the Soldering Guide.
Lift the mother board out of the device.
A weak adhesive attaches the motherboard to the device.
The red wire in the picture will not be attached to your device at this point.
Orient the device sideways, as shown in the picture.
Lightly push the front of the display to separate it from the front panel.
The battery in the picture will not be attached to the device at this point.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
