跳转到主内容
Palm TX Battery Pack Replacement
你所需要的
  1. Palm TX Battery Pack Replacement, Back Panel: 步骤 1 中的图像 1,2 Palm TX Battery Pack Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Battery Pack Replacement: 步骤 2 中的图像 1,1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Battery Pack Replacement: 步骤 3 中的图像 1,2 Palm TX Battery Pack Replacement: 步骤 3 中的图像 2,2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Battery Pack Replacement: 步骤 4 中的图像 1,2 Palm TX Battery Pack Replacement: 步骤 4 中的图像 2,2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Battery Pack Replacement: 步骤 5 中的图像 1,2 Palm TX Battery Pack Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Battery Pack Replacement, Battery Pack: 步骤 6 中的图像 1,2 Palm TX Battery Pack Replacement, Battery Pack: 步骤 6 中的图像 2,2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
结论
5等其他人完成本指南。
Spencer Lewson
于01/19/11注册
793 声望
创作了6篇指南
团队
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011 的会员
CPSU-AMIDO-W11S1G15
4 名成员
创作了7篇指南
一条评论
In step 1 - Also remove the cover hinge by sliding downwards
In step 3 - there are actually 2 crevices on the left side of the device. Use the larger, which originally held the cover hinge (the smaller crevice seems to remove the facia)
Jack - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 28
总计 7,069
