跳转到主内容
加入维修社区 - 创建账户
PSP 300xc Motherboard Replacement
你所需要的
  1. PSP 300xc Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 PSP 300xc Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc Motherboard Replacement, Front Case: 步骤 2 中的图像 1,1
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc Motherboard Replacement: 步骤 3 中的图像 1,2 PSP 300xc Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc Motherboard Replacement: 步骤 6 中的图像 1,2 PSP 300xc Motherboard Replacement: 步骤 6 中的图像 2,2
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc Motherboard Replacement, LCD: 步骤 7 中的图像 1,1
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc Motherboard Replacement: 步骤 8 中的图像 1,2 PSP 300xc Motherboard Replacement: 步骤 8 中的图像 2,2
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc Motherboard Replacement: 步骤 9 中的图像 1,1
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc Motherboard Replacement: 步骤 10 中的图像 1,1
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc Motherboard Replacement: 步骤 11 中的图像 1,3 PSP 300xc Motherboard Replacement: 步骤 11 中的图像 2,3 PSP 300xc Motherboard Replacement: 步骤 11 中的图像 3,3
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc Motherboard Replacement, Home Bar: 步骤 13 中的图像 1,3 PSP 300xc Motherboard Replacement, Home Bar: 步骤 13 中的图像 2,3 PSP 300xc Motherboard Replacement, Home Bar: 步骤 13 中的图像 3,3
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
  14. PSP 300xc Motherboard Replacement, Trigger Buttons: 步骤 14 中的图像 1,2 PSP 300xc Motherboard Replacement, Trigger Buttons: 步骤 14 中的图像 2,2
    • Remove both trigger buttons by lifting them off the PSP 300xc.
  15. PSP 300xc Motherboard Replacement, Power Switch Board: 步骤 15 中的图像 1,1
    • Using a finger or spudger, flip up the retaining flap on the power switch board ribbon cable socket.
    • Pull the ribbon cable out of its socket.
  16. PSP 300xc Motherboard Replacement: 步骤 16 中的图像 1,1
    • Using the flat end of a spudger, pry the power switch board up and off the PSP 300xc.
    • Remove the power switch board from the PSP.
  17. PSP 300xc Motherboard Replacement, Power Jack: 步骤 17 中的图像 1,1
    • Remove a single Phillips screw securing the power jack to the PSP.
  18. PSP 300xc Motherboard Replacement: 步骤 18 中的图像 1,1
    • Using the flat edge of a spudger, pry the small black tab away from the power jack to free it from the case.
  19. PSP 300xc Motherboard Replacement: 步骤 19 中的图像 1,1
    • Disconnect the power jack from its connector on the motherboard by pulling it straight out of its socket.
  20. PSP 300xc Motherboard Replacement, Analog Stick: 步骤 20 中的图像 1,1
    • Using the flat end of a spudger, peel the 'L' trigger contact pad up from the case.
  21. PSP 300xc Motherboard Replacement: 步骤 21 中的图像 1,2 PSP 300xc Motherboard Replacement: 步骤 21 中的图像 2,2
    • Using a fingernail or spudger, flip up the retaining flap on the d-pad and 'L' trigger ribbon cable.
    • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
  22. PSP 300xc Motherboard Replacement: 步骤 22 中的图像 1,1
    • Remove a single Phillips screw securing the analog stick to the PSP 300xc.
  23. PSP 300xc Motherboard Replacement: 步骤 23 中的图像 1,2 PSP 300xc Motherboard Replacement: 步骤 23 中的图像 2,2
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the analog stick ribbon connector.
    • Lift the analog stick out of the PSP 300xc, disconnecting the ribbon cable as you remove it.
  24. PSP 300xc Motherboard Replacement, Motherboard: 步骤 24 中的图像 1,1
    • Push the small black tab holding the right speaker to the left.
    • The speaker will pop out of place.
  25. PSP 300xc Motherboard Replacement: 步骤 25 中的图像 1,1
    • Using the flat edge of a spudger, pry the wireless board cable connector straight up and off the motherboard.
  26. PSP 300xc Motherboard Replacement: 步骤 26 中的图像 1,3 PSP 300xc Motherboard Replacement: 步骤 26 中的图像 2,3 PSP 300xc Motherboard Replacement: 步骤 26 中的图像 3,3
    • Using a fingernail or spudger, flip up the retaining flap on the following three ZIF connectors.
    • Action button contact pad ribbon
    • UMD drive ribbon
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Use your fingernail or tip of a spudger to push both sides of the black retaining flap on the UMD laser ribbon socket to the right.
    • Use your fingers or a spudger to gently pull all three ribbon cables straight out of their sockets.
  27. PSP 300xc Motherboard Replacement: 步骤 27 中的图像 1,2 PSP 300xc Motherboard Replacement: 步骤 27 中的图像 2,2
    • Lift the right silver rim up and off the PSP 300xc
    • Lift the left silver rim up and off the PSP 300xc
  28. PSP 300xc Motherboard Replacement: 步骤 28 中的图像 1,2 PSP 300xc Motherboard Replacement: 步骤 28 中的图像 2,2
    • Lift the motherboard up from its bottom edge about 45 degrees from the case.
    • Slowly attempt to pull the motherboard out at roughly a 45 degree angle from the case.
    • It takes a little fidgeting to get the motherboard to come apart from the case.
结论
15等其他人完成本指南。
Matthew Newsom
于01/05/10注册
42,235 声望
创作了67篇指南
3指南评论
looking for bottom stick board
louie khalil - 回复 分享
part No. 0402071
buttons is not working the right side
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 37
过去 30 天: 144
总计 11,503
