本指南有最近更改,您可查看未经巡查的最新版本。
简介
Is your Memory Slot just not performing as well as it used to? Fix it!
你所需要的
Place PSP face down, so that the UMD Drive is facing upwards.
Locate the battery door and open.
Remove the battery from inside.
Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
Remove the sticker using the PSP Opening Tools.
Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
Slide off the left trigger along with the plastic bracket underneath.
Carefully pry off left trigger button using opening tools.
15等其他人完成本指南。
2条评论
Thank you, i'am Zakaria Farid from Morocoo
would this work for a 2001 model?
