当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Place PSP face down, so that the UMD Drive is facing upwards.
Locate the battery door and open.
Remove the battery from inside.
This step requires the removal of the warranty sticker. Removing the sticker will void the warranty . According to the FTC removing this will not void your warranty.
Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
Remove the sticker using the PSP Opening Tools.
Under the sticker is a 5mm Phillips screw needed in the next step.
Remove four 5 mm Phillips from the case.
If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
Gently pry the front bezel away from the casing using a PSP opening tool.
Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
With the home bar out of the way, gently pry up the display using the opening tools.
There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
Gently lift out the display.
Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
Slide off the left trigger along with the plastic bracket underneath.
Carefully pry off left trigger button using opening tools.
The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
