跳转到主内容
PS Vita Slim Back Camera Replacement
你所需要的
  1. PS Vita Slim Back Camera Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
    • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
    • There are four screws on the back of the device, remove them as shown.
  2. PS Vita Slim Back Camera Replacement: 步骤 2 中的图像 1,2 PS Vita Slim Back Camera Replacement: 步骤 2 中的图像 2,2
    • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
  3. PS Vita Slim Back Camera Replacement: 步骤 3 中的图像 1,3 PS Vita Slim Back Camera Replacement: 步骤 3 中的图像 2,3 PS Vita Slim Back Camera Replacement: 步骤 3 中的图像 3,3
    • The next step will require the opening tool.
    • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
    • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
    • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
  4. PS Vita Slim Back Camera Replacement: 步骤 4 中的图像 1,1
    • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
  5. PS Vita Slim Back Camera Replacement, Back Camera: 步骤 5 中的图像 1,3 PS Vita Slim Back Camera Replacement, Back Camera: 步骤 5 中的图像 2,3 PS Vita Slim Back Camera Replacement, Back Camera: 步骤 5 中的图像 3,3
    • The back camera is fastened to the motherboard via a ribbon cable .
    • So first we must remove the casing, remove the two 6.35 mm screws using a J00 screwdriver.
    • After the screws have been removed, carefully remove the black casing.
  6. PS Vita Slim Back Camera Replacement: 步骤 6 中的图像 1,3 PS Vita Slim Back Camera Replacement: 步骤 6 中的图像 2,3 PS Vita Slim Back Camera Replacement: 步骤 6 中的图像 3,3
    • With the black casing removed, next we need to remove the top camera frame casing.
    • You will need to remove the two 6.35 mm using a J00 screwdriver.
    • After the screws have been removed you can then carefully remove the camera frame casing. You can also now see the camera itself.
    • You can now remove the camera, but you must be careful to not damage it.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 47
总计 2,997
