你所需要的
Open the memory protection
Remove gently the rear cover
When re-assembly take care to the thin tabs
This connector is directly to the board
This Flex connector need to be unplug
The 321 battery is there
You can add some thermal glue to fix the battery
I did it with a small piece of scotch
即将完成!
To re-assembly your device follow the step backward
结论
由衷感谢以下译者:
fr en
100%
Bertrand PIGEARD正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
