跳转到主内容
Oster 6329 Circuit Board Resistor Replacement
你所需要的
  1. Oster 6329 Circuit Board Resistor Replacement, Outer Shell Removal: 步骤 1 中的图像 1,2 Oster 6329 Circuit Board Resistor Replacement, Outer Shell Removal: 步骤 1 中的图像 2,2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Circuit Board Resistor Replacement: 步骤 2 中的图像 1,1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Circuit Board Resistor Replacement: 步骤 3 中的图像 1,1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Circuit Board Resistor Replacement: 步骤 4 中的图像 1,2 Oster 6329 Circuit Board Resistor Replacement: 步骤 4 中的图像 2,2
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Circuit Board Resistor Replacement: 步骤 5 中的图像 1,2 Oster 6329 Circuit Board Resistor Replacement: 步骤 5 中的图像 2,2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Oster 6329 Circuit Board Resistor Replacement, Circuit Board Resistor: 步骤 6 中的图像 1,1
    • Using a #1 phillips head screwdriver, remove the four 1cm philips head screws holding the circuit board to the inside of the toaster shell.
  7. Oster 6329 Circuit Board Resistor Replacement: 步骤 7 中的图像 1,1
    • Grasp the circuit board and pull on it perpendicular to the attached surface.
  8. Oster 6329 Circuit Board Resistor Replacement: 步骤 8 中的图像 1,1
    • Inspect the circuit board for any burnt or otherwise damaged components. Be sure to carefully identify the damaged components that need replacement. For help identifying resistor values look at wikipedia's electronic color code article.
  9. Oster 6329 Circuit Board Resistor Replacement: 步骤 9 中的图像 1,1
    • Use the soldering kit to unsolder the damaged component. For soldering Instructions look at the iFixit Soldering Guide.
  10. Oster 6329 Circuit Board Resistor Replacement: 步骤 10 中的图像 1,1
    • Once the damaged component has been unsoldered from the circuit board, remove it.
结论
另外一个人完成了本指南。
Timothy Grijalva
于01/31/14注册
234 声望
创作了2篇指南
团队
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G15
5 名成员
创作了6篇指南
一条评论
Where are replacement parts for a toaster available typically?
Bruce odom - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 16
总计 2,128
