跳转到主内容
Oster 16-Speed Blender Power Cord Replacement
你所需要的
  1. Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: 步骤 1 中的图像 1,2 Oster 16-Speed Blender Power Cord Replacement, Fan and Motor: 步骤 1 中的图像 2,2
    • Remove the Blender Container from the Blender Base.
  2. Oster 16-Speed Blender Power Cord Replacement: 步骤 2 中的图像 1,2 Oster 16-Speed Blender Power Cord Replacement: 步骤 2 中的图像 2,2
    • Flip the blender so the bottom is facing you.
  3. Oster 16-Speed Blender Power Cord Replacement: 步骤 3 中的图像 1,3 Oster 16-Speed Blender Power Cord Replacement: 步骤 3 中的图像 2,3 Oster 16-Speed Blender Power Cord Replacement: 步骤 3 中的图像 3,3
    • Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
  4. Oster 16-Speed Blender Power Cord Replacement: 步骤 4 中的图像 1,2 Oster 16-Speed Blender Power Cord Replacement: 步骤 4 中的图像 2,2
    • Remove the plastic bottom from the base of the blender.
  5. Oster 16-Speed Blender Power Cord Replacement: 步骤 5 中的图像 1,2 Oster 16-Speed Blender Power Cord Replacement: 步骤 5 中的图像 2,2
    • Holding the center of the fan, grip the knob in the center of the top of the blender with a wrench and twist the wrench counterclockwise.
  6. Oster 16-Speed Blender Power Cord Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the motor and fan from the base of the blender.
  7. Oster 16-Speed Blender Power Cord Replacement: 步骤 7 中的图像 1,3 Oster 16-Speed Blender Power Cord Replacement: 步骤 7 中的图像 2,3 Oster 16-Speed Blender Power Cord Replacement: 步骤 7 中的图像 3,3
    • Now, gently pull the white wire that is connected to the base and the motor.
    • Be careful, as there is a spring behind the contact points, that might try to shoot out and hurt you.
  8. Oster 16-Speed Blender Power Cord Replacement: 步骤 8 中的图像 1,3 Oster 16-Speed Blender Power Cord Replacement: 步骤 8 中的图像 2,3 Oster 16-Speed Blender Power Cord Replacement: 步骤 8 中的图像 3,3
    • Now, turn the motor over, and remove the black wire from the motor.
    • Again, be warned as the is another spring that wants to shoot out and hurt you here as well.
  9. Oster 16-Speed Blender Power Cord Replacement: 步骤 9 中的图像 1,2 Oster 16-Speed Blender Power Cord Replacement: 步骤 9 中的图像 2,2
    • Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
    • Be careful, as there is another, black wire, nearby that you do not want to de-solder.
  10. Oster 16-Speed Blender Power Cord Replacement, Circuit Board: 步骤 10 中的图像 1,3 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: 步骤 10 中的图像 2,3 Oster 16-Speed Blender Power Cord Replacement, Circuit Board: 步骤 10 中的图像 3,3
    • Locate the four 11mm screws in the circuit board.
    • Unscrew the four screws using the Phillips #1 screwdriver.
  11. Oster 16-Speed Blender Power Cord Replacement: 步骤 11 中的图像 1,2 Oster 16-Speed Blender Power Cord Replacement: 步骤 11 中的图像 2,2
    • Desolder the circuit board from the base at the indicated point, following the directions by clicking here.
    • Now separate the circuit board from the base.
  12. Oster 16-Speed Blender Power Cord Replacement: 步骤 12 中的图像 1,3 Oster 16-Speed Blender Power Cord Replacement: 步骤 12 中的图像 2,3 Oster 16-Speed Blender Power Cord Replacement: 步骤 12 中的图像 3,3
    • You will see that the circuit board is still attached by a red wire and a black wire.
    • Flip the circuit board back over and desolder at the indicated points following the directions given here.
  13. Oster 16-Speed Blender Power Cord Replacement, Power Cord: 步骤 13 中的图像 1,1
    • You do not have to completely remove the circuit board to replace the power cord. You can, if desired, skip the steps of de-soldering the yellow wire, and the circuit board from the base.
    • De-solder the black wire from the circuit board, and then carefully remove the black wire.
    • Now you can solder on the new power cord.
结论
4等其他人完成本指南。
Dana
于04/14/14注册
773 声望
创作了5篇指南
团队
Cal Poly, Team 12-37, Maness Spring 2014 Cal Poly, Team 12-37, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G37
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 36
总计 3,154
