跳转到主内容
Oral-B White Pro 1000 Motherboard Replacement
你所需要的
  1. Oral-B White Pro 1000 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Motherboard Replacement: 步骤 2 中的图像 1,3 Oral-B White Pro 1000 Motherboard Replacement: 步骤 2 中的图像 2,3 Oral-B White Pro 1000 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Pry open the end cap from the toothbrush body.
    • Remove the spring.
  3. Oral-B White Pro 1000 Motherboard Replacement: 步骤 3 中的图像 1,2 Oral-B White Pro 1000 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
  4. Oral-B White Pro 1000 Motherboard Replacement: 步骤 4 中的图像 1,2 Oral-B White Pro 1000 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use flat head screwdriver to remove power button pressure plate.
  5. Oral-B White Pro 1000 Motherboard Replacement: 步骤 5 中的图像 1,3 Oral-B White Pro 1000 Motherboard Replacement: 步骤 5 中的图像 2,3 Oral-B White Pro 1000 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
  6. Oral-B White Pro 1000 Motherboard Replacement: 步骤 6 中的图像 1,2 Oral-B White Pro 1000 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
  7. Oral-B White Pro 1000 Motherboard Replacement: 步骤 7 中的图像 1,2 Oral-B White Pro 1000 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
结论
Reattach new motherboard and reassemble your device following instructions in reverse order. Solder appropriate connections during reassembly.
2等其他人完成本指南。
Hannah Parker
于11/08/17注册
203 声望
撰写一个指南
团队
IUPUI, Team S5-G4, Baechle Fall 2017 IUPUI, Team S5-G4, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S5G4
3 名成员
创作了6篇指南
一条评论
Motor are brushless?
joseferreira_ms - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 60
总计 2,611
