跳转到主内容
Opening the Galaxy Watch3
你所需要的
  1. Opening the Galaxy Watch3, Unfasten the back cover screws: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
  2. Opening the Galaxy Watch3, Wedge open the back cover: 步骤 2 中的图像 1,2 Opening the Galaxy Watch3, Wedge open the back cover: 步骤 2 中的图像 2,2
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
  3. Opening the Galaxy Watch3, Disconnect the sensor flex cable: 步骤 3 中的图像 1,3 Opening the Galaxy Watch3, Disconnect the sensor flex cable: 步骤 3 中的图像 2,3 Opening the Galaxy Watch3, Disconnect the sensor flex cable: 步骤 3 中的图像 3,3
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Opening the Galaxy Watch3, Remove the back cover: 步骤 4 中的图像 1,2 Opening the Galaxy Watch3, Remove the back cover: 步骤 4 中的图像 2,2
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
结论
另外一个人完成了本指南。
Tobias Isakeit
于03/31/14注册
119,221 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,092篇指南
3条评论
where can I get the galaxy watch3 rubber gasket?
regards
Miguel Vera - 回复
That’s a good question. As for the previous models it is very hard to find those rubber gaskets. Using a “liquid rubber gasket” might be one solution to that. (Use carefully to not spill too much on and into the watch)
Tobias Isakeit -
I tried to remove all of the screws from the back cover, but 3 of the 4 screws remained and seemed to be fused to the main base of the watch. One of the screws was stripped. Now only 1 screw is engaged with the back cover. (I might need to replace the back cover. My watch is glitching which is draining the battery. I would like to fix the problems myself. Where can I get specific advice?
Antoinette - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 103
总计 2,477
