简介
To get into the device, the bottom of the toothbrush needs to be removed. This is difficult and the toothbrush can get damaged in the process. For models where the bottom has a hole, you could try this alternative method first. If you are lucky, it will work without causing any damage.
The basic idea: A suitable machine screw is screwed into the hole on the bottom cover.
Then you can pull the cover off by hand with a lot of force and feeling. Good luck!
Here you can clearly see the two clamps that hold the innards in place. Those must be compressed when removing the cover.
It is advisable to also replace the seal on the drive at the same time. If it leaks, moisture will get into the device. Look closely at the seal, there are two different types.
Work through the steps in reverse order to reassemble your device.
9等其他人完成本指南。
由衷感谢以下译者:
100%
oldturkey03正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7条评论
yes, thank you for the tip to use a screw. it was really difficult and resorted to also using some metal spudgers and lucky I didn’t jab my hands (pro tip: put some leather work gloves on!)
another pro tip I learned from a YouTube video, is to take wire cutters and snip off the 2 clips that make it so difficult to get this thing off.
there is enough friction at play that the clips are not needed and you can just pull out the assembly much easier in the future.
That worked absolutely fine for me. I used a 8 thread tap to prepare the hole and then an M8x70mm screw to pull out.
Danke, deine Anleitung hat geholfen. Jetzt vibriert die Zahnbürste wieder schön. ich hab den Spalt zwischen dem Magneten und dem Motor etwas erweitert. Leider musste ich feststellen, das die weiße Dichtung oben eingerissen ist. Kannst du mir sagen , wo ich so eine Dichtung bekommen kann?
