跳转到主内容
Opening the Siemens Surpresso Compact
你所需要的
  1. Opening the Siemens Surpresso Compact, Opening the Siemens Surpresso Compact: 步骤 1 中的图像 1,1
    • Unplug your coffee maker!
    • Remove the water container, the brew group and the drip tray with pomace container.
    • Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
    • Depending on the model, additional sensors with cables may be installed on the top and side panels. You have to remove these before you can completely remove the housing parts.
  2. Opening the Siemens Surpresso Compact: 步骤 2 中的图像 1,1
    • Remove the two Torx T10 screws on the top.
  3. Opening the Siemens Surpresso Compact: 步骤 3 中的图像 1,2 Opening the Siemens Surpresso Compact: 步骤 3 中的图像 2,2
    • Remove seven T10 Torx screws on the back.
    • The two screws at the bottom of the front can remain.
  4. Opening the Siemens Surpresso Compact: 步骤 4 中的图像 1,2 Opening the Siemens Surpresso Compact: 步骤 4 中的图像 2,2
    • Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
    • Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
    • Lift the top off.
    • On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
  5. Opening the Siemens Surpresso Compact: 步骤 5 中的图像 1,2 Opening the Siemens Surpresso Compact: 步骤 5 中的图像 2,2
    • Slide the side section of the brewing unit about 2 cm to the rear. This sometimes gets stuck and may require some force to remove.
    • Remove the two tabs from the power switch.
    • Take off the side panel with the brew group.
  6. Opening the Siemens Surpresso Compact: 步骤 6 中的图像 1,1
    • Do the same with the panel on the other side.
    • To remove the water tank hose simply pull it of the pump.
    • Remove the side panel.
结论
To reassemble your device, follow the steps in reverse order.
15等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
202,783 声望
创作了246篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
25 名成员
创作了1,109篇指南
3条评论
Sehr gut beschrieben und bebildert, danach kann man gut arbeiten, Danke.
h.kornetzki - 回复
Wie bekomme ich den vorderen Gehäusedeckel ab? Ich muss den Dampfschalter tauschen.
sabine.gorski - 回复
Hab ich noch nie gemacht. Sicher muss der Auslauf weg: Siemens Surpresso Compact Kaffeeauslaufverteiler austauschen, suche dann die Schrauben und Rasten. Gutes Gelingen, wir würden uns freuen, wenn du das für iFixit dokumentierst!
VauWeh -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 68
总计 7,386
