跳转到主内容
Open all the windows simultaneously.
  1. Open all the windows simultaneously., Open all the windows with the door lock: 步骤 1 中的图像 1,3 Open all the windows simultaneously., Open all the windows with the door lock: 步骤 1 中的图像 2,3 Open all the windows simultaneously., Open all the windows with the door lock: 步骤 1 中的图像 3,3
    • Insert the ignition key in the driver's door lock.
    • Turn the key clockwise to unlock.
    • Hold the key in this position for 5 seconds.
    • All the windows begin rolling down. Releasing the key to the neutral position stops the windows.
  2. Open all the windows simultaneously., Open all the windows with the remote transmitter (key fob): 步骤 2 中的图像 1,2 Open all the windows simultaneously., Open all the windows with the remote transmitter (key fob): 步骤 2 中的图像 2,2
    • Press the door unlock button on the remote transmitter.
    • Press and hold the door unlock button on the remote transmitter a second time.
    • All the windows roll down simultaneously. Releasing the button stops the windows where they are.
    • If you press and hold the unlock button again within 10 seconds, the windows continue rolling down further.
    • Hold the button down for only a moment to crack the windows a few inches.
  3. Open all the windows simultaneously., Close all the windows using the door lock.: 步骤 3 中的图像 1,2 Open all the windows simultaneously., Close all the windows using the door lock.: 步骤 3 中的图像 2,2
    • To close all the windows at once, insert the ignition key in the driver's door lock.
    • Visually verify that no one, particularly children, have hands or other body parts in the windows when closing!
    • Turn the key counterclockwise once to lock the vehicle.
    • Release the key to the neutral position.
    • Turn and hold the key counterclockwise again.
    • The windows begin closing in 5 seconds.
    • It's not possible to close all the windows with the remote transmitter.
终点
4等其他人完成本指南。
David Spalding
于11/12/15注册
6,473 声望
创作了12篇指南
4条评论
hi this use to work on my vectra
but not on my sv6 any ideas
paul.maryanne - 回复
This guide is meant for the Honda CL9, sold as the Euro/JDM Accord or US Acura TSX. Your experience will undoubtedly differ with other makes and models. Consult your owners manual or local dealer.
David Spalding -
This was very helpful. But I have a 2006 XLE Limited Toyota and it does not work. Any ideas as to why?
Harrison King - 回复
Different model car? Check hour car’s manual, or your Toyota dealer. ;)
David Spalding -
添加评论
浏览统计数据:
过去 24 小时: 43
过去 7 天: 302
过去 30 天: 1,082
总计 103,025
