简介
This guide shows how to replace the motherboard on the Oontz Angle 3 Ultra in the case of water damage or other types of damage. The device would likely not work or have a strange behavior. Follow this guide to replace the motherboard and get the Oontz Angle 3 Ultra working again.
你所需要的
在这个步骤中使用的工具:Tweezers$4.99
Remove the two black rubber sheaths around the edges of the speaker.
Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
Using a soldering iron, remove microphone wires attached to the motherboard.
Melt the solder on the battery terminals on the motherboard and pull the wires through the backside of the board.
For more information on soldering, please visit the How to Solder and Desolder Connections guide.
另外一个人完成了本指南。
3条评论
Greetings.
Where can I find boards for my Angle 3 Ultra ??
Same problem
can we have the parts of mother board so we as a beginner in electricians need this
