跳转到主内容
OontZ Angle 3 Speaker Replacement
你所需要的
  1. OontZ Angle 3 Speaker Replacement, Back Case: 步骤 1 中的图像 1,3 OontZ Angle 3 Speaker Replacement, Back Case: 步骤 1 中的图像 2,3 OontZ Angle 3 Speaker Replacement, Back Case: 步骤 1 中的图像 3,3
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
  2. OontZ Angle 3 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
  3. OontZ Angle 3 Speaker Replacement: 步骤 3 中的图像 1,2 OontZ Angle 3 Speaker Replacement: 步骤 3 中的图像 2,2
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
  4. OontZ Angle 3 Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 OontZ Angle 3 Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to remove the front speaker plate from the speaker.
  5. OontZ Angle 3 Speaker Replacement: 步骤 5 中的图像 1,2 OontZ Angle 3 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the eight (8) 5.25mm screws with the Phillips #0 screwdriver.
    • Open access to the speakers by letting them rest as shown.
  6. OontZ Angle 3 Speaker Replacement: 步骤 6 中的图像 1,2 OontZ Angle 3 Speaker Replacement: 步骤 6 中的图像 2,2
    • Use the soldering iron to carefully disconnect the speaker(s) from the motherboard connection wires.
    • Learn more about soldering here.
    • Remove the disconnected speaker(s).
    • When reconnecting the wires to the new speaker(s), be careful to connect the wires to the correct nodes (red for positive and black for negative). If they are reconnected to the wrong locations the speakers will either not work or break.
结论
10等其他人完成本指南。
Mason Hollander
于01/20/16注册
1,387 声望
创作了4篇指南
团队
USF Tampa, Team 15-6, Remmell Spring 2016 USF Tampa, Team 15-6, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G6
4 名成员
创作了4篇指南
7条评论
Where do you buy replacement speakers?
michalfiona - 回复
Where do you buy the replacement speakers?
What type to buy?
michalfiona - 回复
where i buy the speaker replacement/
Sharina Uadan - 回复
Where can i buy the replacement speakers
Anil Meda - 回复
same question, I am looking for original speaker for oontz angle 3 and I can’t find one. Those who are looking for the size, its 40x40mm (1.57”) 4ohms 3W
Dwayne Champ Manuel - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 97
总计 8,295
