跳转到主内容
OnePlus 5T Back Cover Replacement
你所需要的
  1. OnePlus 5T Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 OnePlus 5T Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Before you begin, switch off your phone.
    • Remove the SIM card tray.
  2. OnePlus 5T Back Cover Replacement: 步骤 2 中的图像 1,1
    • Remove the two Torx T2 screws (2.5 mm length).
    • The OnePlus 5T doesn't use a lot of adhesive to secure the backcover, however the clamps are very strong and require some force during the opening procedure.
  3. OnePlus 5T Back Cover Replacement: 步骤 3 中的图像 1,3 OnePlus 5T Back Cover Replacement: 步骤 3 中的图像 2,3 OnePlus 5T Back Cover Replacement: 步骤 3 中的图像 3,3
    • Insert an opening tool between the display and the backcover at the bottom end of the phone.
    • Use the opening tool to create a gap between back cover and display.
    • Insert an opening pick in the gap you created with the opening tool.
  4. OnePlus 5T Back Cover Replacement: 步骤 4 中的图像 1,3 OnePlus 5T Back Cover Replacement: 步骤 4 中的图像 2,3 OnePlus 5T Back Cover Replacement: 步骤 4 中的图像 3,3
    • Slide the opening pick to the bottom right corner of the phone.
    • Insert a second opening pick and slide it to the bottom left corner of the phone.
  5. OnePlus 5T Back Cover Replacement: 步骤 5 中的图像 1,3 OnePlus 5T Back Cover Replacement: 步骤 5 中的图像 2,3 OnePlus 5T Back Cover Replacement: 步骤 5 中的图像 3,3
    • Slide the opening pick around the bottom left corner and then up along the left edge of the phone to open the plastic clamps that secure the backcover.
  6. OnePlus 5T Back Cover Replacement: 步骤 6 中的图像 1,3 OnePlus 5T Back Cover Replacement: 步骤 6 中的图像 2,3 OnePlus 5T Back Cover Replacement: 步骤 6 中的图像 3,3
    • Slide the opening pick around the bottom right corner and then up along the right edge of the phone to open the plastic clamps that secure the backcover.
  7. OnePlus 5T Back Cover Replacement: 步骤 7 中的图像 1,3 OnePlus 5T Back Cover Replacement: 步骤 7 中的图像 2,3 OnePlus 5T Back Cover Replacement: 步骤 7 中的图像 3,3
    • Try not to remove the backcover all the way yet. The fingerprint and the charging port and headphone flex cables are still connected to the motherboard.
    • Flip your phone and carefully lift the bottom end of the backcover away from the phone assembly. Fold it to left and hold it at an 80° angle.
  8. OnePlus 5T Back Cover Replacement: 步骤 8 中的图像 1,2 OnePlus 5T Back Cover Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
  9. OnePlus 5T Back Cover Replacement: 步骤 9 中的图像 1,3 OnePlus 5T Back Cover Replacement: 步骤 9 中的图像 2,3 OnePlus 5T Back Cover Replacement: 步骤 9 中的图像 3,3
    • Twist the backcover around 180° and lay it down to align the bottom end of the backcover the top edge of the battery.
  10. OnePlus 5T Back Cover Replacement: 步骤 10 中的图像 1,3 OnePlus 5T Back Cover Replacement: 步骤 10 中的图像 2,3 OnePlus 5T Back Cover Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the small metal shield which covers the battery and the charging port and headphone jack flex cable connectors.
  11. OnePlus 5T Back Cover Replacement: 步骤 11 中的图像 1,2 OnePlus 5T Back Cover Replacement: 步骤 11 中的图像 2,2
    • Use a spudger to pry up and disconnect the charging port and headphone jack flex cable.
  12. OnePlus 5T Back Cover Replacement: 步骤 12 中的图像 1,2 OnePlus 5T Back Cover Replacement: 步骤 12 中的图像 2,2
    • Remove the backcover.
结论
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
5等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
210,046 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 47
总计 3,134
