跳转到主内容
加入维修社区 - 创建账户
OneLink Safe and Sound Bluetooth Module Replacement
你所需要的
  1. OneLink Safe and Sound Bluetooth Module Replacement, Cover: 步骤 1 中的图像 1,2 OneLink Safe and Sound Bluetooth Module Replacement, Cover: 步骤 1 中的图像 2,2
    • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
    • Remove plastic rim.
    询问修复机器人
  2. OneLink Safe and Sound Bluetooth Module Replacement: 步骤 2 中的图像 1,2 OneLink Safe and Sound Bluetooth Module Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
    询问修复机器人
  3. OneLink Safe and Sound Bluetooth Module Replacement: 步骤 3 中的图像 1,2 OneLink Safe and Sound Bluetooth Module Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
    • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
  4. OneLink Safe and Sound Bluetooth Module Replacement: 步骤 4 中的图像 1,1
    • Use tweezers to unplug the speaker cable from the motherboard.
    询问修复机器人
  5. OneLink Safe and Sound Bluetooth Module Replacement: 步骤 5 中的图像 1,2 OneLink Safe and Sound Bluetooth Module Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to remove the microphone connection from the motherboard.
    • Remove the top of the device.
    询问修复机器人
  6. OneLink Safe and Sound Bluetooth Module Replacement, Bluetooth Module: 步骤 6 中的图像 1,1
    • Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
    询问修复机器人
  7. OneLink Safe and Sound Bluetooth Module Replacement: 步骤 7 中的图像 1,2 OneLink Safe and Sound Bluetooth Module Replacement: 步骤 7 中的图像 2,2
    • Lift the Bluetooth module off of the daughterboard.
    • Lift it straight up to avoid bending the delicate pins that connect the Bluetooth module to the board.
    询问修复机器人
结论
团队
UMass Dartmouth, Team 2-2, Petersen Fall 2022 UMass Dartmouth, Team 2-2, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G2
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 28
总计 378
