跳转到主内容
Olympus Stylus 410 Battery Cover Replacement
你所需要的
  1. Olympus Stylus 410 Battery Cover Replacement, Slider: 步骤 1 中的图像 1,1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Battery Cover Replacement: 步骤 2 中的图像 1,1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Battery Cover Replacement: 步骤 3 中的图像 1,1
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Battery Cover Replacement: 步骤 4 中的图像 1,1
    • The slider should now be free from the body of the camera.
  5. Olympus Stylus 410 Battery Cover Replacement, Outer Case: 步骤 5 中的图像 1,3 Olympus Stylus 410 Battery Cover Replacement, Outer Case: 步骤 5 中的图像 2,3 Olympus Stylus 410 Battery Cover Replacement, Outer Case: 步骤 5 中的图像 3,3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Olympus Stylus 410 Battery Cover Replacement: 步骤 6 中的图像 1,2 Olympus Stylus 410 Battery Cover Replacement: 步骤 6 中的图像 2,2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. Olympus Stylus 410 Battery Cover Replacement: 步骤 7 中的图像 1,2 Olympus Stylus 410 Battery Cover Replacement: 步骤 7 中的图像 2,2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Olympus Stylus 410 Battery Cover Replacement: 步骤 8 中的图像 1,2 Olympus Stylus 410 Battery Cover Replacement: 步骤 8 中的图像 2,2
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  9. Olympus Stylus 410 Battery Cover Replacement: 步骤 9 中的图像 1,3 Olympus Stylus 410 Battery Cover Replacement: 步骤 9 中的图像 2,3 Olympus Stylus 410 Battery Cover Replacement: 步骤 9 中的图像 3,3
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  10. Olympus Stylus 410 Battery Cover Replacement: 步骤 10 中的图像 1,1
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  11. Olympus Stylus 410 Battery Cover Replacement: 步骤 11 中的图像 1,2 Olympus Stylus 410 Battery Cover Replacement: 步骤 11 中的图像 2,2
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  12. Olympus Stylus 410 Battery Cover Replacement, Battery Cover: 步骤 12 中的图像 1,2 Olympus Stylus 410 Battery Cover Replacement, Battery Cover: 步骤 12 中的图像 2,2
    • Open the battery cover and lift it up and off of back camera case.
  13. Olympus Stylus 410 Battery Cover Replacement: 步骤 13 中的图像 1,3 Olympus Stylus 410 Battery Cover Replacement: 步骤 13 中的图像 2,3 Olympus Stylus 410 Battery Cover Replacement: 步骤 13 中的图像 3,3
    • Locate and unscrew the 2 screws with a #00 Phillips screwdriver.
    • Remove the black seal.
  14. Olympus Stylus 410 Battery Cover Replacement: 步骤 14 中的图像 1,2 Olympus Stylus 410 Battery Cover Replacement: 步骤 14 中的图像 2,2
    • Slide the metal piece off of the battery cover.
  15. Olympus Stylus 410 Battery Cover Replacement: 步骤 15 中的图像 1,1
    • This is what the battery cover and back case look like completely disassembled.
结论
另外一个人完成了本指南。
Rory Aronson
于04/15/10注册
46 声望
创作了6篇指南
团队
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G13
5 名成员
创作了17篇指南
一条评论
i need Battery where i can find it thinks
uae20162017 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,936
