跳转到主内容
Olympus Pen E-PL7 LCD Screen Replacement
你所需要的
  1. Olympus Pen E-PL7 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Olympus Pen E-PL7 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 LCD Screen Replacement, LCD Screen: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  3. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 3 中的图像 1,2 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Fully extend the LCD assembly.
  4. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 4 中的图像 1,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 4 中的图像 2,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top LCD bracket.
  5. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 5 中的图像 1,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 5 中的图像 2,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may fall off after the screws have been removed.
  6. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 6 中的图像 1,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 6 中的图像 2,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  7. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 7 中的图像 1,2 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Use tweezers to peel back the plastic cover.
    Be very careful i destroyed the wrong cables in that step.
    christoph hütt - 回复
  8. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 8 中的图像 1,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 8 中的图像 2,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
  9. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 9 中的图像 1,2 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Gently pull the ribbon cable out with tweezers.
  10. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the LCD Screen.
    Thank you so much. Just fixed my cam!
    Ingo - 回复
    There is more to it than shown here. You must remove the circuit board from the back of the old LCD screen, unplug those ribbon cables, transfer the circuit board to the new screen, and plug in the cables.
    Steve Reynolds - 回复
结论
6等其他人完成本指南。
Kelsea Weber
于11/12/15注册
19,877 声望
创作了32篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,259篇指南
7条评论
Magnifico
Great Work!!
apuntotres - 回复
Where can I buy a replacement LCD screen?
Joshua Almeida - 回复
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
josollis - 回复
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Stephan Fagerer - 回复
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
ah to lee - 回复
Same problem, stuck in selfie mode. Upside down display in normal mode. Hope somebody could help. Thanks!
Rick Velasquez - 回复
Je rencontre le même problème d'image inversé. Pas trouvé de solution ailleurs pour le moment...
Olivier Piebourg - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 98
总计 9,885
