跳转到主内容
Olympus Pen E-PL7 LCD Screen Replacement
你所需要的
  1. Olympus Pen E-PL7 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Olympus Pen E-PL7 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 LCD Screen Replacement, LCD Screen: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  3. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 3 中的图像 1,2 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Fully extend the LCD assembly.
  4. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 4 中的图像 1,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 4 中的图像 2,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top LCD bracket.
  5. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 5 中的图像 1,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 5 中的图像 2,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may fall off after the screws have been removed.
  6. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 6 中的图像 1,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 6 中的图像 2,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  7. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 7 中的图像 1,2 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Use tweezers to peel back the plastic cover.
  8. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 8 中的图像 1,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 8 中的图像 2,3 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
  9. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 9 中的图像 1,2 Olympus Pen E-PL7 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Gently pull the ribbon cable out with tweezers.
  10. Olympus Pen E-PL7 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the LCD Screen.
结论
6等其他人完成本指南。
Kelsea Weber
于11/12/15注册
20,047 声望
创作了32篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,067篇指南
7条评论
Magnifico
Great Work!!
apuntotres - 回复
Where can I buy a replacement LCD screen?
Joshua Almeida - 回复
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
josollis - 回复
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Stephan Fagerer - 回复
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
ah to lee - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 102
总计 10,148
